Wed, Dec 11, 10:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
Subject: I Have a Question...
EClark1894 ( ) posted Sun, 27 October 2019 at 4:14 PM ยท edited Wed, 11 December 2024 at 10:37 PM
I have installed the 11.272 update on the 19th, and haven't done anything else since except start up Poser. A few days after the install, I started getting a couple of error messages. I clicked on them and they went away and Poser continued running like nothing had happened. So why am I getting these messages? Here's a screenshot of one of these messages.
ironsoul ( ) posted Sun, 27 October 2019 at 5:32 PM
File timestamps are stored in the directory structure associated with a folder. The error suggests the permissions on the folder are incorrect. You can test to see if its a Poser or Windows problem by attempting to open the directory in Windows Explorer and see if it generates the same error.
EClark1894 ( ) posted Sun, 27 October 2019 at 5:39 PM
Two things: Windows Explorer doesn't have the same problem, but the file path isn't quite right. There is no Documents folder present, but there IS a Public Documents folder.
ghostship2 ( ) posted Sun, 27 October 2019 at 9:20 PM
Hey Earl I have been getting those errors for a couple of years now. I just ignore them. I get one error when Poser accesses my library for the first time after starting the program and I get the same error a second time when clicking on my Mats library folder. After that no more errors and everything works fine so I've never bothered with it.
ironsoul ( ) posted Sun, 27 October 2019 at 11:30 PM
EClark1894 posted at 3:57AM Mon, 28 October 2019 - #4368496
That's normal, they are the same folder. Not a windows folder permission issue then. Other thoughts, could changing the library search options help, could the default scene contain a reference to a material that no longer exists - not looking to waste your time, just trying to generate some ideas. .
EClark1894 ( ) posted Mon, 28 October 2019 at 5:02 AM
Will check.
Bejaymac ( ) posted Tue, 29 October 2019 at 6:25 AM
W10 has a different folder structure for "Users/Public" than older versions of windows, if the devs are still using W7 for instance then they wont have any idea it's been changed, that's probably what's causing that error.
EClark1894 ( ) posted Tue, 29 October 2019 at 6:36 AM
Well, the error window and message are coming up, but it doesn't seem to be affecting the library search and loading at all.
