Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 16 2:29 pm)
It sounds to me like you're taking the 'long way around', and may not be aware that Poser Pro already has a Face Room for creating custom faces and heads?
Poser's default format is OBJ ( wavefront object )
according to the website
Export to Filmbox (FBX), 3D Studio (3DS), Maya ASCII (ma), Lightwave 6.x LWO2 (LWO), Wavefront (OBJ), Softimage dotXSI 3.0 (XSI), VRML 97 (WRL) or STL including all expression morph targets if desired.
and the faceroom does not work with all figures.
Locked Out
Could you use this OBJ-free workflow? Or will the DSON not handle FaceGen-made heads sent over from the DAZ runtime?
FaceGen to a Genesis 2 head in DAZ, save.
Then into Poser via the free DSON converter.
Then manually fit the head onto a Poser character?
I got it. The exported OBJ or 3ds load directly into poser, no problems, just have to save the face map as JPEG or the head comes out purple. The eyes lack life but practice will remedy that. I've never been able to make realistic heads of real people before. Thanks you for your replies, I would not have taken this quite expensive step without your information.
what face generator did you get? Face shop 8 works with La femme, while face shop 9 does not. Face shop 9 adds vertexes. Or at least for me. But it really does not give realistic heads. So if you have a better one, let me know.
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
Hi, I have tried loading an OBJ produced in a windows prog, but it is not a suitable OBJ. Now I'm considering buying FaceGen core. It says heads can be exported to OBJs but are they the type that can be loaded into PP11.
Thanks
