Wed, Jan 22, 10:57 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 22 9:24 am)
Subject: "out of memory" warning
malcolm474 ( ) posted Mon, 18 November 2019 at 8:25 PM · edited Wed, 22 January 2025 at 10:56 AM
I was working with Poser 10 today. I got a warning that I was out of memory and that I should save my work. Before I had a chance to save my work, the program closed. It is very frustrating, since I had been working on the program for a long time and lost all my work. This is a quirk that I have experience with Poser ever since I started using it long ago. Poser warns you that you are out of memory and need to save your work, and then Poser closes before you have a chance to do it. It would be nice if somebody fixed this.
Nails60 ( ) posted Tue, 19 November 2019 at 4:44 AM
If you have got a 64 bit system it might be a good idea to consider upgrading to poser 11. Poser 10 is a 32 bit program and as such can only use a limited amount of of ram, about 2gig if I remember correctly, while poser 11 is a 64 bit program and can essentially use all your system memory. After this happened to me I decided then to upgrade to poser pro 2014 which was 64 bit and never had the trouble again.
Since the only version of poser now available is poser 11.2, and only in 64 bit form, I would say the chance of any updates to poser 10 as zero.
malcolm474 ( ) posted Tue, 19 November 2019 at 12:26 PM
I appreciate your messages, Nails60. You really make a conscientious effort to address these concerns. That being said, I have Poser 11 Pro and it was working fine until I installed the upgrade. Now, the animation palette takes forever to refresh every time I edit something. I couldn't figure out anyway to address this, so I had to abandon Poser 11 altogether and revert to Poser 10. There is a tension between the demands of these upgrades and the ability of computers to meet them. I think that they should make it possible to edit the functions provided to accommodate computers that can't handle the full program.
Nails60 ( ) posted Tue, 19 November 2019 at 5:19 PM
Yes I saw your post on another thread after I posted this message, but too late to delete it.
KageRyu ( ) posted Mon, 09 December 2019 at 2:08 AM
Online Now!
I have not seen this error myself since the days of Poser 4... which OS are you operating on? I recommend frequent saves - I have lost progress to crashes myself, it is very frustrating.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
hornet3d ( ) posted Thu, 19 December 2019 at 7:16 AM
At least with Poser 11 you can set up the auto save, it can be a pain at times but it should stop the loss of a total project. Being able to limit the auto save time and number of versions also helps limits the impact. I do not have too many crashes with Poser 11 but auto save has saved me a great deal of time all the same.
redwulf ( ) posted Mon, 06 January 2020 at 10:23 PM · edited Mon, 06 January 2020 at 10:29 PM
I use Poser 11 Pro and since the latest upgrade was able to pose my G2f/m just fine, Since the upgrade every time I I try to pose these characters I find that the clothing poses but the character does not. Not sure what I am doing wrong of if this is a known glitch.
Also, maybe I have stayed with V4 much too long but when I try to use G3F some of the models turn mannequin black and look like a store model from a store display, what did I do wrong? BTW they work just fine In Firefly just not Superfly.
I know these are probably answer back in archives some place but I got a little disconnected for a while after losing a family member for several years, and want to get back into my old hobby again. Thanks for any help!
hornet3d ( ) posted Tue, 07 January 2020 at 5:19 AM
redwulf posted at 11:05AM Tue, 07 January 2020 - #4375755
The problem with Superfly renders showing figures as mannequin black is a common problem with figures and not limited to V4. While SM tried to make Superfly backwards compatible there are some nodes used in Firefly that Superfly just does not understand. For most the solution is to run the figure through EZSkin 3 - (Free stuff @ snarlygribbly.org/poser) which will correct the majority of the problems. Another problem that comes up is either ghostly eyes where they are rendered milky white or washed out tones, the latter not only on figures but props also this is almost always down to the use of 'alternate specular' in the material set up which again Superfly has problems with. That is not to say it cannot be used with Superfly but generally the way it is set up for Firefly does not work in Superfly. It should also be noted that such problems are often the result of 'cheats' used in Firefly that are no longer required in Superfly.
If you want to look in further depth is you go to the material room and use advanced any node that is an issue for Superfly will be denoted by a dotted line between nodes.
redwulf ( ) posted Wed, 08 January 2020 at 1:09 AM
Thanks for the reply, I am having more problems with gen 2 characters than I do with V4 with which I have been using Snarly's EZskins3 program since it came out. I do really like its performance. it does not however support the Gen 2 Characters, but the clue you gave about checking nodes will be investigated and I m sure I will find a work around! Thanks again Hornet, you input is invaluable to me... hope I can return the favor one day!
hornet3d ( ) posted Wed, 08 January 2020 at 9:27 AM
redwulf posted at 3:26PM Wed, 08 January 2020 - #4375867
Happy if I have helped, I am afraid I do not use gen 2 characters so I am not able to help in that respect. I am afraid I moved on to Dawn SE and as she worked 'out of the box' I took the easy way out.
