Fri, Jan 3, 7:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 7:06 am)
Subject: La Femme and Dynamic Clothing
arrow1 ( ) posted Fri, 29 November 2019 at 2:23 PM · edited Fri, 03 January 2025 at 7:08 AM
Although I have been using Poser since Poser 4 I have never been successful using dynamic clothing! However with La Femme I would like to give it a go! Firstly do I have to use Dynamic Clothing especially made for La Femme or can I use Victoria 4's Dynamic Clothing? I have lots of her dynamic clothing plus other Poser Figures Dynamic Clothing. Also can anyone point me to a step by step tutorial I mean step by step as I am a not young and my brain is getting old and I am a total dummy when it comes to Dynamics.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Glitterati3D ( ) posted Fri, 29 November 2019 at 4:29 PM
Can I say, first and foremost, please use a dynamic piece purchased from one of the excellent vendors who really do dynamic clothing properly. Mesh Density and Design really affect a successful simulation, and when you are trying to learn something, it's important to eliminate potential problems that you can probably avoid or fix when you have some experience, with a well designed product.
Second, with the advent of Poser 11 it's necessary to set up your simulation and then SAVE the file before running the sim. Most instructions you find in tutorials will not mention this as it only became an necessity with P11..
Here's a cloth room tutorial to get you started: https://www.renderosity.com/mod/tutorial_premium/?page=info&tutorial=11
Afrodite-Ohki ( ) posted Fri, 29 November 2019 at 4:29 PM · edited Fri, 29 November 2019 at 4:30 PM
If you get V4's dynamic clothing to fit LaFemme decently in the starting pose, you can use that! You can use scaling and translating on the clothing, and if needed, morph brush or magnets for a better fit. Avoid pokethroughs.
Edit: I was gonna walk you through it but Glitterati beat me to it - better use an actual tutorial 😁
Feel free to call me Ohki!
Kalypso ( ) posted Sat, 30 November 2019 at 6:00 AM
Site Admin
You can download Frequency's tutorials from Freestuff.
I second what Glitterati said about starting with a dynamic product specifically made for La Femme as you are not likely to have issues interfering with learning how to use dynamics. I believe there is dynamic clothing for La Femme included with the Poser update. Also, vendors will almost always include any special instructions for their product as well if needed. Later you can experiment fitting items from other figures and/or freestuff clothing.
Should you run into any problems you're sure to find help in the forum.
Have fun :)
FVerbaas ( ) posted Sat, 30 November 2019 at 7:02 AM · edited Sat, 30 November 2019 at 7:07 AM
Forum Coordinator
If you want to use V4 based dynamic clothing on La Femme, you can use the prefitter with LaFemme injection to make the initial fit. Use the Prefitter cr2 as collision object and in a sim morph to the La Femme shape.
Alternative idea, not tested yet: Load the Prefitter cr2 and La Femme into the scene, zero La Femme. in the Prefitter set LaFemme morph to 1.0 so Prefitter lines up with LaFemme and copy the V4 to LaFemme morph from the Prefitter into La Femme. Delete the Prefitter and in La Femme set that morph to -1.0 at the start of the simulation (the garment should then more or less fit La Femme. and to 0.0 somewhere in the run of the sim. LF will then gradially morph from roughly V4 shape to her own shape. Of course if you save the LF to V4 morph for La Femme you need to do the copy from the Prefitter only once.
Keep in mind that for dynamic clothing size is important. If you try to sim an XXL size model into an M size garment, the result will be an M size garment spanning around an XXL person. The garment does not grade up. Likewise, pants that would stay put on an L size figure end up around the ankles of an M size figure, unless you make the belt constrained.
generation2235 ( ) posted Fri, 10 January 2020 at 6:53 PM
I'm just getting started with LaFemme and my LaFemme figures need clothing. Are there yet any conforming clothing figures for LaFemme or are we as yet sequestored to only dynamic clothing items for the LaFemme figure?
Thanks.
RobZhena ( ) posted Fri, 10 January 2020 at 7:15 PM
There is conforming clothing available in the Marketplace. Please buy some so vendors will keep making it. I also started a thread on converting clothes to conform to La Femme, including making dynamic clothing into conforming figures.
EClark1894 ( ) posted Fri, 10 January 2020 at 8:14 PM · edited Fri, 10 January 2020 at 8:19 PM
I'm going to contradict RobZhena here. Do NOT use conforming clothing as dynamic clothing. I agree with Glitterrati. Use a product from a vendor who specializes in dynamic clothing. In fact, I have a listing in my Directory under "Clothing" that will give you a list of vendors who specialize in dynamic clothing. Dynamic Clothing Vendors
Make sure that your starting and finishing poses do not intersect ANYWHERE on the cloth or figure. Also make sure that there is a good amount of distance between the figure and the actual clothing. Your clothing does not have to actually touch the figure anywhere to collide with it.
RedPhantom ( ) posted Fri, 10 January 2020 at 9:57 PM
Site Admin Online Now!
EClark1894 posted at 9:54PM Fri, 10 January 2020 - #4376175
Actually he was talking about doing the opposite. His instructions turned dynamic clothing into conforming.
EClark1894 ( ) posted Sat, 11 January 2020 at 4:16 AM
RedPhantom posted at 5:15AM Sat, 11 January 2020 - #4376177
EClark1894 posted at 9:54PM Fri, 10 January 2020 - #4376175 Actually he was talking about doing the opposite. His instructions turned dynamic clothing into conforming.
My apologies then.
FVerbaas ( ) posted Sat, 11 January 2020 at 4:37 AM · edited Sat, 11 January 2020 at 4:37 AM
Forum Coordinator
EClark1894 posted at 11:08AM Sat, 11 January 2020 - #4376175
The cloth room is actually quite good at 'curing' moderate poke-thru provided the conditions are right. Keep in mind the garment is described only in the vertex points. At every step, vertex points are checked whether they are not within the collision figure. When they are, they are moved to outside the nearest surface, which, if the distance between opposite sides of the figure is small, could be on the 'wrong' side of the figure. Hands and wrists are notorious for this, as are ankles and feet. Pokes on body parts clothing contacts most frequently: arms, legs, body and neck, usually are ironed out just fine.
Defined genitalia, ears, and any location where skin has complex folds are best stayed clear from. Sometimes they form a maze that clothing vertices cannot escape from.
Afrodite-Ohki ( ) posted Sat, 11 January 2020 at 7:38 AM
On the question if there are conforming clothing items for LaFemme: there's quite the number in her store section, and a few in the freestuff area.
Her store section: https://www.renderosity.com/mod/bcs/?TopID=807077
(There are all kinds of items for her there, including conforming clothing - but also dynamic clothing, hair, characters, accessories, poses...)
EClark1894 ( ) posted Sun, 12 January 2020 at 2:54 AM
That sounds interesting. Wonder if people would like being able to find Dynamic specific clothing for La Femme, separate from conforming? The problem is that I list by vendor in the Directory, not by outfit.
Afrodite-Ohki ( ) posted Sun, 12 January 2020 at 3:50 AM
Yeah probably the only thing I'd add to Renderosity site itself would be specific categories. Like, the ability to get to La Femme's products and then specify that you want hair for her, for instance.
EClark1894 ( ) posted Sun, 12 January 2020 at 5:55 AM
Then we run into catloguing. I'd have to list every product and put a link next to it.
Nails60 ( ) posted Sun, 12 January 2020 at 8:11 AM
Ohki You can do that the other way round. Go to the 3d figure essentials, select hair, select female, select LaFemme. I know this was just an example but you can go to the item type then select LaFemme, sometimes you might have to narrow the item type to female before LaFemme turns up on the list to select.
Afrodite-Ohki ( ) posted Sun, 12 January 2020 at 12:00 PM
Nails60 posted at 2:00PM Sun, 12 January 2020 - #4376319
Wait really? I gotta try that - thanks!
