You are allowed up to three installs at one time, so yes, you can install it on more than one computer, but you can only use it on one of them at a time.
For example, if you have a render running on one of your computers, you cannot open Poser on the other computer to use while you're waiting for the render to complete,
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Hello,
I bought my Poser 11 Pro software May 2019. I installed it once on my computer. Then I upgraded my computer and now it says I have reached my maximum installs. As I read through these posts, it looks like I get 3 installs. Anyone I have contacted on line about this has not been helpful, they keep giving me links to webpages but those have been useless as well. How do I deactivate so I can reactivate my new software ?
If you bought your software in May, it needs a full update since it changed owners.
See here: https://www.renderosity.com/mod/forumpro/?thread_id=2940516
This thread is from 2016.
Poser has been bought a few months ago by Bondware, the company that owns Renderosity. From my understanding, you don't need to deactivate previous installations - but because of the company change, the license server has changed and there's a mandatory update for Poser to continue working. The old Smith Micro Download Manager won't work anymore either.
You can get the update here: https://www.posersoftware.com/downloads
Feel free to call me Ohki!
tabbycat2 posted at 2:16PM Mon, 09 December 2019 - #4372839
I long for the olden times when you didn't have to go through hell to run your software programs.
Eh, I remember having programs that required me to have a CD in my CD drive to load even though they were completely installed to my computer. Took them years to drop that "security" even after CD copying became so easy and cheap.
And before that, having to type enormous serial numbers, cause copy+paste in the setup windows wasn't allowed.
quietrob posted at 2:18PM Mon, 09 December 2019 - #4372836
Let's be clear. Because I had a seamless update I'm not certain of a few things.
Are you saying that installing the new update will give their Poser a new lease on life? They will not even have to deal with activations except the initial one to phone into Bondware and say hello?
From what I understand - and I might be wrong there - the new license server simply ignores previous installations. Buuut it will phone home from time to time. So it shouldn't complain that you had Poser installed in other machines before, but you'll still need to be online at times for the check in that one new installation.
You're very welcome! Don't forget to grab the extra goodies, we get around 8gb worth of gift content with the update
Just wanted to check on this as I'm about to upgrade to Poser Pro 11. What is the seat licence for this as I can't find this info anywhere? I currently have an older version installed on my main PC and my laptop so that one machine can be rendering while I'm working on different software on the other. Does this still apply with the new version?
You can have poser 11 installed on more than one machine, however running more than one at a time is probably against the license restrictions (poser 2014 checked your local network and wouldn't let you run the program on two machines simultaneously). However poser 11 includes queue manager, which allows you to render over a local network without poser itself running on the other machine, so it is quite possible to render on one machine while working on another.. It also has a render in background option.
Nails60 posted at 12:14PM Sat, 30 May 2020 - #4390568
Ah - that's good to know, so it should work the same as my old version. Thanks!
Can Poser Pro 11 be installed on more than one machine?
[Note: I've posted to the RDNA forum too but no response so far]
