Mon, Nov 25, 11:35 PM CST
Subject: Poser 11.2 Geometric Edge Stopped Functioning
DarkSkills ( ) posted Sat, 14 December 2019 at 10:38 PM · edited Mon, 25 November 2024 at 9:42 PM
Hello my friends! Up until 2 days ago, when doing celshaded renders, adjusting the Geometric Edge in the material room was never an issue, and worked exactly as expected. However, it seems to have stopped functioning completely. Regardless of what number I input to adjust its thickness, it has no bearing on the outline, neither in the display window nor final render. I have tried it on multiple files/scenes, and multiple characters, all to no avail. Again, it was functioning as it should up until approximately 2 days ago. Any assistance with this matter is greatly appreciated. Thanks.
Stay Focused.
DarkSkills ( ) posted Sat, 14 December 2019 at 10:50 PM
I should also clarify, I'm not doing preview renders, I'm using Firefly and adjusting the Geometric Edge in that material room.
Stay Focused.
Glitterati3D ( ) posted Sun, 15 December 2019 at 9:13 AM
Can you tell us what, if anything, changed on your computer? Windows update? Update to Poser 11? Video controller update?
Also a bit about your system would be helpful. Windows? Mac? Version? Video adapter? Poser version?
DarkSkills ( ) posted Sun, 15 December 2019 at 11:47 AM · edited Sun, 15 December 2019 at 11:49 AM
I believe I may have found the culprit. The only change which has occured on my PC in the last week or so was a Windows 10 update which ran in the wee hours on 12/12. I performed a system restore to 12/11 and low and behold, the Geometric Edge is functioning as it should again. So it appears that there's something about the latest Windows 10 update that's causing some sort of conflict with Poser 11.2, and at the very least, this conflict is resulting in the Geometric Edge to stop functioning properly.
Here are my PC specs: Dell Desktop PC (close to 5 years old), OS: Windows 10, CPU: i7-4790 @ 3.60GHz, RAM: 24.0 GB DDR3, GPU: NVIDIA GeForce GT 720 (Dedicated GPU memory 1.0 GB, Shared 12.0 GB), C Drive: 1 Terabyte Toshiba DT01ACA100 (Poser and Runtimes are installed here), External Hard Drive: 1 Terabyte Seagate
Stay Focused.
