Sat, Jan 4, 5:03 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Why am I get rough ground shadows in Comic Book Preview
mmitchell_houston ( ) posted Sun, 26 January 2020 at 8:49 PM · edited Thu, 02 January 2025 at 8:41 AM
In my light settings I've increased my various map resolutions to 4096, and have done the same in the render settings (preview). But I'm still getting very rough ground shadows.
I've tried increase the sub-division on the ground plane, but that hasn't helped at all.
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM |  14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com   |   Poser Noir Comics Tutorial   |   Illustrations Honored by Renderosity
bwldrd ( ) posted Mon, 27 January 2020 at 3:59 AM
Try increasing the shadow blur radius in your light properties, see if that helps.
Consider me insane if you wish, but is your reality any better?
mmitchell_houston ( ) posted Mon, 27 January 2020 at 11:33 AM
bwldrd posted at 11:32AM Mon, 27 January 2020 - #4377904
Thank you to replying to my poorly titled post (how the hell did I miss that error in the heading -- I can't even blame it on booze because (for once) I wasn't drinking!). I'll give it a shot tonight and let you know if it works.
mmitchell_houston ( ) posted Tue, 28 January 2020 at 12:04 AM
bwldrd posted at 11:59PM Mon, 27 January 2020 - #4377904
Try increasing the shadow blur radius in your light properties, see if that helps. Thank you, but that had zero effect. I suspected as much because this is a Comic Book Preview, not a Firefly or Superfly render.
I did find a workaround, I'm happy to say. I'm going to keep looking at other settings and see if I can do this without completely changing the source material, but for now, this is an excellent fix.
The ground is a high-resolution ground plane without a texture (that is to say, it has the default Poser material applied).
  1. In the Material Room, I select the Ground Plane.
  2. I then click on the button (far right) "Set up Toon Render."
  3. It asks if I want a specular highlight: I said "No."
  4. The render style of this one item is now set to Toon.
  5. I change the DarkColor property to Black.
Now, when I render I get a nice, crisp shadow on the ground.
As I said, there are other properties to explore, so I'm going to look at them, too. But for now, this is a solid approacch with which I can work.
bwldrd ( ) posted Tue, 28 January 2020 at 12:36 PM
Do you have antialias rendered images turned on in your render settings, for preview rendering?
bwldrd ( ) posted Tue, 28 January 2020 at 12:58 PM
Notice the difference in the highlighted area shadows without versus with antialaising turn off/on. Shouldn't need all the workaround or a ground plane. These renders where with the toon renderer in preview mode, no ground plane but still has shadows.
mmitchell_houston ( ) posted Tue, 28 January 2020 at 1:03 PM
bwldrd posted at 1:02PM Tue, 28 January 2020 - #4378111
Hoo Hoo! Probably not! I will check this evening and let you know. Thank you very much for the tip!
mmitchell_houston ( ) posted Wed, 29 January 2020 at 1:06 AM
bwldrd posted at 1:05AM Wed, 29 January 2020 - #4378115
Thank you, but it turns out that I did have the anti-alias box checked.
Are you working with Toon renders? I'm using Texture Shaded with the Comic Book Preview turned on. I suspect that has something to do with it. But if you have any other ideas, I'm game to try them!
RedPhantom ( ) posted Wed, 29 January 2020 at 7:17 AM
Site Admin
If you look, you only have it checked on the right side. The left side, where the problem is, doesn't have it checked.
mmitchell_houston ( ) posted Wed, 29 January 2020 at 9:46 AM
RedPhantom posted at 9:42AM Wed, 29 January 2020 - #4378213
Thanks for input. Definitely appreciated.
But that's not my image: My image is the one with the guy and the gun. bwldrd has the image with the cute robot, and he was showing me a "Before and After" look at the effects of anti-aliasing.
Turns out that anti-aliasing doesn't seem to have any discernible effect on Comic Book Preview renders.
bwldrd ( ) posted Wed, 29 January 2020 at 12:05 PM
I have done some renders using the comic book filter, both color and B&W. But have never really paid much attention to the ground shadows, as the B&W where relatively clean like the one posted, and the color ones are usually so dark toned you can't see shadows anyhow.
mmitchell_houston ( ) posted Wed, 29 January 2020 at 12:11 PM
bwldrd posted at 12:10PM Wed, 29 January 2020 - #4378240
Thanks. I'm going to reach out to artist Brian Haberlin via Facebook and see if he can offer any insights. At least for the moment I can use the Toon Texture workaround.
bwldrd ( ) posted Wed, 29 January 2020 at 12:24 PM
Only other thing I can think of is what are the sample settings for your antialiasing. It goes from 1 to 8. I have mine set at 8.
RedPhantom ( ) posted Wed, 29 January 2020 at 4:35 PM
Site Admin
Sorry about not seeing who posted. Try increasing the preview shadow map size. It's on the propteries tab for your light.
