Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 04 10:44 pm)
If you have a Download folder in your Library, refer to the image below:
Once you determine the path, click on the show in Explorer link to open the browser. By doing this, you will see if the current folder contains any content. Now, if your path leads to Program Files folder and you are running any Windows version above Vista then UAC blocking any content to be loaded there without administrative privileges. Another question, have you searched your hard drive for any additional runtimes?
A simple drive search will call up all the folders named Downloads or runtime. Which operating system are you currently using? If you are using Windows 7, 8 or 10 and you installed Poser using its default settings then you should find a Downloads folder in the location I highlighted in the image above. That pathway is Users>Public>Documents>Poser 11 Content>Downloads.
I always download my content from Renderosity, purchased or free, and install from the compressed file through Winzip, my preferred method. It is also possible to install through Poser itself, even though I prefer to see the folders in the compressed file to make certain everything is in the proper order. What methodology are you using to install Poser content?
I thought I restored my download section in my Poser library. I have problem. It will not allow me to download any new or old props and other materals back into Poser for me. What want wrong?
