Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
If you have a good hi-res image of the collar laid flat on a single colour background you may consider the procedure I followed for some images in my gallery:
Both are simple single 'cloth' items textured with images I found in the open access collection of the Met museum. I rendered in Firefly using displacement and normal mapping from a de-saturated copy of the image, and transparency mapping via step functions. It takes a few tries to tune the shader but renders quite quickly.
Easy enough to make, if a bit tedious. A fully modelled version would be ridiculously high poly, too.
Tucan-Tiki posted at 9:56AM Wed, 04 March 2020 - #4382096
I'm not sure if this is a Poser/ Daz figure but that does look like T pose I found this on Facebook. In non poser post.
Neither thats a mannequin, Its an actual piece called Egyptian Goddess (custom made) @ $1,750.00+
Pretty piece I think its made by LuXVivensFashions
HP Zbook 17 G6, intel Xeon 64 GB of ram 1 TB SSD, Quadro RTX 5000
Not quite as shiny but a lot more authentic: LaFemme wearing the 'Broad Collar of Wah',
Broad Collar of Wah
ca. 1981–1975 B.C.
This broad collar is one of the finest examples of its type from the early Middle Kingdom. It was carefully designed using beads of diminishing lengths to create the curved form. Although a few areas needed reinforcing with modern thread, the stringing is almost entirely original. The collar is part of a set of funerary jewelry belonging to Wah, the estate manager of Meketre.
Wah's broad collar, anklets, and bracelets were made as funerary ornaments for the burial and were found in the layers of linen wrapping that were closest to the body; the collar had been tied around the neck, the bracelets and anklets had been laid over the lower arms and legs. They are all made of a ceramic material called Egyptian faience. Beaded jewelry sets of this type are illustrated in the object friezes that decorate many Middle Kingdom coffins, and fragmentary examples have been found in numerous tombs of the period.
On view at The Met Fifth Avenue in Gallery 105
Public Domain
Object Details
Period: Middle Kingdom
Dynasty: Dynasty 12
Reign: reign of Amenemhat I, early
Date: ca. 1981–1975 B.C.
Geography: From Egypt, Upper Egypt, Thebes, Southern Asasif, Tomb of Wah (MMA 1102), Mummy, in wrappings on chest, MMA excavations, 1920
Medium: Faience, linen thread
Dimensions: H. 34.5 cm (13 9/16 in.); W. 39 cm (15 3/8 in.)
Credit Line: Rogers Fund and Edward S. Harkness Gift, 1940
Accession Number: 40.3.2
I made this as a proof of concept, using some shortcuts. The image 'cut' can do with improvements (see the rough edges) and the mesh is now a tri-mesh where for a final product one would probably use radial quad here.can be done easily provided you invest the time. If there is interest I can provide the files.
