Fri, Feb 14, 12:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Ok this needs to be made anyone up to that?
Tucan-Tiki ( ) posted Sat, 29 February 2020 at 12:16 AM · edited Fri, 14 February 2025 at 12:54 PM
beer-in-ancient-egypt-6-80x80.jpgPhotos-of-Lavish-Pieces-of-ancient-Egyptian-jewelry-1.jpg
Tucan-Tiki ( ) posted Sat, 29 February 2020 at 12:19 AM · edited Sat, 29 February 2020 at 12:20 AM
I'm not sure if this is a Poser/ Daz figure but that does look like T pose I found this on Facebook. In non poser post.
FVerbaas ( ) posted Sat, 29 February 2020 at 4:32 AM
Forum Coordinator
If you have a good hi-res image of the collar laid flat on a single colour background you may consider the procedure I followed for some images in my gallery:
Both are simple single 'cloth' items textured with images I found in the open access collection of the Met museum. I rendered in Firefly using displacement and normal mapping from a de-saturated copy of the image, and transparency mapping via step functions. It takes a few tries to tune the shader but renders quite quickly.
FVerbaas ( ) posted Sat, 29 February 2020 at 6:55 AM
Forum Coordinator
On looking back it may not have been the Met open access. Anyway there is plenty such stuff avaialble in the collections put online by the various museums.
SamTherapy ( ) posted Sat, 29 February 2020 at 12:36 PM
Easy enough to make, if a bit tedious. A fully modelled version would be ridiculously high poly, too.
Kerya ( ) posted Sun, 01 March 2020 at 2:31 AM
Square stitch with seed beads for most of the parts, peyote stitch for the cabochon settings, I am not sure about the flat round beads on the upper part of the wings ...
Sorry, I couldn't resist.
CHK2033 ( ) posted Wed, 04 March 2020 at 9:58 AM · edited Wed, 04 March 2020 at 10:07 AM
Tucan-Tiki posted at 9:56AM Wed, 04 March 2020 - #4382096
Neither thats a mannequin, Its an actual piece called Egyptian Goddess (custom made) @ $1,750.00+
Pretty piece I think its made by LuXVivensFashions
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
FVerbaas ( ) posted Wed, 04 March 2020 at 3:19 PM · edited Wed, 04 March 2020 at 3:21 PM
Forum Coordinator
Not quite as shiny but a lot more authentic: LaFemme wearing the 'Broad Collar of Wah',
Broad Collar of Wah
ca. 1981–1975 B.C.
This broad collar is one of the finest examples of its type from the early Middle Kingdom. It was carefully designed using beads of diminishing lengths to create the curved form. Although a few areas needed reinforcing with modern thread, the stringing is almost entirely original. The collar is part of a set of funerary jewelry belonging to Wah, the estate manager of Meketre.
Wah's broad collar, anklets, and bracelets were made as funerary ornaments for the burial and were found in the layers of linen wrapping that were closest to the body; the collar had been tied around the neck, the bracelets and anklets had been laid over the lower arms and legs. They are all made of a ceramic material called Egyptian faience. Beaded jewelry sets of this type are illustrated in the object friezes that decorate many Middle Kingdom coffins, and fragmentary examples have been found in numerous tombs of the period.
On view at The Met Fifth Avenue in Gallery 105
Public Domain
Object Details
Period: Middle Kingdom
Dynasty: Dynasty 12
Reign: reign of Amenemhat I, early
Date: ca. 1981–1975 B.C.
Geography: From Egypt, Upper Egypt, Thebes, Southern Asasif, Tomb of Wah (MMA 1102), Mummy, in wrappings on chest, MMA excavations, 1920
Medium: Faience, linen thread
Dimensions: H. 34.5 cm (13 9/16 in.); W. 39 cm (15 3/8 in.)
Credit Line: Rogers Fund and Edward S. Harkness Gift, 1940
Accession Number: 40.3.2
I made this as a proof of concept, using some shortcuts. The image 'cut' can do with improvements (see the rough edges) and the mesh is now a tri-mesh where for a final product one would probably use radial quad here.can be done easily provided you invest the time. If there is interest I can provide the files.
FVerbaas ( ) posted Thu, 05 March 2020 at 1:02 PM
Forum Coordinator
BTW: there is a flat image of the collar the OP showed, size 1500x1383 in the Etsy store of the maker. It is not the 3400x3900 of the image of the collar in the MET, but it is evenly lit, mostly flat, and comes quite some way.
