Sun, Jan 26, 1:33 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 25 9:35 pm)
banner
Subject: Poser 11 Pro not saving my last render
Minyassa ( ) posted Sun, 01 March 2020 at 1:31 AM · edited Fri, 24 January 2025 at 6:59 PM
At some point recently, Poser stopped caching my last render. I used to be able to partially render a scene and then go back and area render until it was finished, since it takes me hours and hours to render a full pic and I can't have my only computer tied up that long. I just lost 6 hours of rendering, it has just completely dumped the last render I did and what's on the render tab is the next to last spot render from testing. It's done this before, I just forgot it was doing that. It also only caches ONE render. What is the point of having all these timestamped cache points if there's no images attached to them? Something must be wrong. It's never saved more than about five or six old renders but this new thing of dumping the very last thing I did is horrible. I have 11.2.276 in on Windows 7.
adp001 ( ) posted Sun, 01 March 2020 at 1:56 AM
To put your mind at ease for now: Poser actually stores images reliably. If it doesn't work for you, it will most likely not be a problem Poser causes.
What about disk space?
Minyassa ( ) posted Sun, 01 March 2020 at 3:49 AM
I have plenty of disk space. It just suddenly stopped saving the very last thing I render. It will save several renders previous to the last one. I could go in and do 5 test renders right now and it will save the first four of them.
adp001 ( ) posted Sun, 01 March 2020 at 5:56 AM
What happens if you close the preview-tab after a render and open it again? Does the last render exist in the folder and is just not shown by Poser? Maybe it helps if you use file-explorer to delete anything in the preview-folder. And you should make sure that access rights for the directory are correct.
This is very strange...
RedPhantom ( ) posted Sun, 01 March 2020 at 6:53 AM
Site Admin
Which version of poser are you using? several versions of 11.2 had a problem but they fixed it in 11.2.307. You might need to update.
Minyassa ( ) posted Sun, 01 March 2020 at 12:26 PM
RedPhantom posted at 1:26PM Sun, 01 March 2020 - #4382227
11.2.276. I must've missed the notification of an update, I'll go look. Thank you.
Minyassa ( ) posted Sun, 01 March 2020 at 2:11 PM
@RedPhantom--that was it. Updating fixed it. I did a handful of spot renders, closed the program, re-opened it, and all of them including the last one were there. What a weird glitch to let me know I needed to update! Thanks for the nudge.
