Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 13 6:20 am)
As far as the over scaling, on the properties tab, uncheck the include scales.
For the only including part of the geometry, I've only seen this happen when I didn't use the auto grouping and the clothing I was converting contained groups I check. (like left and right buttocks when the new figure didn't have them.) I don't know if this has anything to do with your problem.
Hmmm, I'll have to investigate that a bit more. Sounds like good advice to check against what my piddly experience is with Poser and the Fitting Room.
---Wolff On The Prowl---
Hi,
So now that I have the Fitting Room working (installed the newest Release Candidate) now I have a new issue.
I made a Catsuit for La'Femme using the Rig Suit supplied for her and reworking it in ZBrush, lowering the density ALLOT and adding in material zones. I'm PRETTY sure it's welded so I don't think that's the issue but when I set up a new Fitting session and saved it as a conformer, went back to the Pose room and realized after about 1/2 hour that the visible suit was still the prop, hid that and low and behold, all that was left of the Fitting Rooms efforts were the Shorts and the Collar from the Catsuit. The Fitting Room I guess discarded the rest of the suit completely, like it's not there at all.
Also I set up the "suit" to inherit all the morphs, including the L'Homme morphs, that didn't go well either. Applying the L'Homme morph the suit ... well it wasn't pretty. Over scaled and out of whack so that's a bust too.
I'll be happy enough if I can get this Fitting Room issue resolved so the entire Catsuit makes it rather than just bits and pieces of it! LOL
Thanks for the help!
Richard
My Store is HERE
My Freebies are HERE
