Mon, Feb 3, 6:48 AM CST
Subject: Poser Pro 11.3, Shut down
Notsrella ( ) posted Mon, 30 March 2020 at 4:06 PM ยท edited Mon, 03 February 2025 at 3:52 AM
Hello, 11.3 seems to be working fine. However when the program is closed I get 'Poser Pro executable file has stopped working..check on line for a solution...close the program' Which has, of course, already happened! Looking at the 'Problem details' ...'Fault module name python27.dll' and 'Fault module version 2.7.17150.1013' and 'Fault module time stamp 5e815992'
As I say the program seems to work ok but this closing message could get irritating.
hborre ( ) posted Mon, 30 March 2020 at 4:31 PM
Did you reboot your system as instructed by install? If you did, I would repeat that step again. Otherwise, it sounds like you may need to go through the whole installation process again to see if it corrects itself.
Notsrella ( ) posted Tue, 31 March 2020 at 4:02 AM
Hello hborre, Thanks for replying. I did as you suggested but I'm afraid it still comes up with the message on closure. As I say the actual program runs fine so I'm not going to get hysterical about it. As I said in the 'problem details' the python27.dll file is mentioned. Could this be a factor?
hborre ( ) posted Tue, 31 March 2020 at 11:29 AM
It could be a factor. I have python errors whenever I resave a scene. It all began with some sort of incompatibility between Snarly's scripts in Poser Pro 2014 and Poser 11 Pro. It's an annoyance but as long as it doesn't disrupt my workflow or corrupt files, I'll manage.
Notsrella ( ) posted Tue, 31 March 2020 at 2:41 PM
Thanks again, hborre, I've a dislike of .dll's . My first (low spec.) computer, had Win 95. Every time I switched on some .dll. would be missing and the d----d thing wouldn't run! That was long ago. A world without imperfection seems to be unattainable! Keep safe!
