Thu, Sep 19, 6:40 PM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Another useful lib: Python Dynamics
adp001 ( ) posted Wed, 04 March 2020 at 8:01 AM · edited Tue, 20 August 2024 at 4:22 AM
https://www.pydy.org/documentation.html
maur_2005 ( ) posted Fri, 13 March 2020 at 6:22 PM
it looks very interesting, There was a project called 'poser physics', unfortunately I think it was discontinued
adp001 ( ) posted Fri, 13 March 2020 at 11:30 PM
maur_2005 posted at 5:25AM Sat, 14 March 2020 - #4383482
Sadly this lib will not work with Poser. Because it needs SymPy & co. And a newer numerics library than the stoneaged lib that comes with Poser.
an0malaus ( ) posted Sat, 21 March 2020 at 2:47 PM · edited Sat, 21 March 2020 at 2:48 PM
@adp001 there may be hope that SymPy can be incorporated into Poser. NumPy and SciPy updates certainly can. Check this thread: Using SciPy module in PoserPro2012 where I've posted instructions. The packages need to be installed in an OS level Python 2.7 and linked into Poser Python to be accessible.
I see indications that Python 2.7.17 may bundle with Poser (at least on Windows), so some of the prerequisites and the ability to use pip and other package managers directly from within Poser may become available again. Hopefully they will do the same with macOS Poser Python 😁 [Hopeful]
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
adp001 ( ) posted Sun, 22 March 2020 at 4:21 AM
@an0malaus
Thanks,
I'm not so tight to Poser anymore. Because I move over to Blender. I have no plans to use Bondware-Poser any longer.
maur_2005 ( ) posted Tue, 31 March 2020 at 8:39 PM
I found this useful lib for physics: http://pyode.sourceforge.net/
