Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
However, you must be aware that the poses never will convert 1:1
This is due to different joint centres, limbs/torso length, and other factors. So you will always need to somewhat fix the poses.
I know this isn't much of a consolation--
but even poses made for the SAME base figure will work differently, depending on the dialed-in morphs/characters.
Just imagine a pose made for a short fat man with his hands resting on his thighs while sitting.
Now apply the same pose to a tall thin man, and you'll see what this is about.
K
You can convert G3F poses to G2F using a fan-written utility in DS (https://www.daz3d.com/forums/discussion/137491/converting-g3-poses-to-g2-it-works/p1), and then export those to Poser using the Poser Format Exporter utility (https://www.daz3d.com/forums/viewthread/6869/). You then apply them in Poser using DSON. This conversion is time consuming and a PITA (you have to individually name in the export utility and point to the folder for every individual exported pose, and then you have to apply the pose to a figure in Poser and re-save it so you get an icon image), so you REALLY have to want those particular poses. I've gone to the trouble, for example, for i13's daily activity poses for G3F. Genesis 2 poses are close to the Rosetta Stone of poses. They work well with almost any figure, including V4, La Femme, Pauline, PE, Loretta LoRez, and Dawn (plus the analogous male figures) . I have never explored converting G8 poses because they are almost always G3 re-treads.
I want to use g3 & g8 poses on V4 - is there a way to convert these poses over to V4 ?
Beware-The Smoking Man Still Lives!
