But be very careful when deciding to uncompress your files. If you have a large drive or have a dedicated secondary drive then go ahead and decompress those files. Otherwise, if space is at a premium then don't. You will find how quickly your disk real estate will diminish if you have a lot of content.
hborre posted at 9:35AM Mon, 25 May 2020 - #4390090
You don't HAVE to decompress any file unless your uncompressed file is missing. One other thing to remember though, the utility comes with a choice to delete any file you uncompress. Unless you have a copy of that file somewhere else, another machine, another drive or a thumb drive, my suggestion is DON'T!
Poser compression uses normal gzip compression, so you can compress/uncompress any Poser files with your archiving program of choice (I recommend the free "7zip"). Just make sure to pick the correct filename extension (.obj / .obz) etc.
"clickety-click -> Here's an overview about all valid extensions
K
KarinaKiev, WinZip does do RAR files among others. I have been using WinZip since before the beginning of the internet. (I know, I'm dating myself)
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
As noted in this forum and others, occasionally, you can't seem to find an .obj file. I f this ever happens to you, try this Poser tip, look for the same file but labelled with obz. Obz files are the compressed file versions of obj. files. Now for a second tip: Poser comes with a file compressor and uncompressor. Simply look under the Scripts Menu until you find "Utility". Click on this and you will see two entries, one labeled "Compress Poser files", and the other labeled "uncompress Poser files". These Utilities will Compress or uncompress any Poser file with a . fcz, ppz, mz5, hrz, pzz, obj, crz, mcz, p2z, and cmz
