Sat, Jan 25, 12:06 PM CST
Subject: Poser 8 - sorry been away from it for a long time and need a catch up
Silverspider ( ) posted Wed, 30 September 2020 at 4:32 AM ยท edited Sat, 25 January 2025 at 11:14 AM
Hi everyone, Ive been away from poser for many years and finally have the need to get back to it but have discovered that there have been many changes since my poser 8. I understand that smith micro is no longer as far as Poser is concerned. So far Ive discovered that it doesn't like windows 10. Is there a work around. I have tried to get it to run under compatibility for windows vista but i don't think my graphics card liked it and I'm so desperate to get it working again.
Thanks everso much, sorry if this is in the wrong place but just had no idea where to put my query
kind regards
Gilly
randym77 ( ) posted Wed, 30 September 2020 at 5:51 AM
There may not be an easy fix, I'm afraid. The problem people run into with Poser 8 is that it used Flash for the library. Some people got it to work by installing an old version of Flash, and applying the latest updates to Poser 8, but that is a security risk, and not recommended. Flash is going away very soon anyway.
You could run Poser 8 without the library, using Explorer instead. It's clunky, but it works.
Another issue you might run into is that Windows 10 doesn't like the runtime installed where Poser used to install it, in Program Files. If you put it somewhere else, that should fix it.
Upgrading to the current version of Poser is probably the best thing to do. You can try it free for 21 days, and there's upgrade pricing.
https://www.posersoftware.com/downloads
Silverspider ( ) posted Wed, 30 September 2020 at 6:41 AM
randym77 posted at 12:38PM Wed, 30 September 2020 - #4400678
Thanks randym77, I'm seriously considering the upgrade, just got to see if i can justify the expense even though its a lot cheaper than I expected.
ghostship2 ( ) posted Wed, 30 September 2020 at 9:14 AM
Online Now!
keep in mind that once Poser 12 is out (end of October) Poser 11 and it's reduced price is gone and you WILL have to buy Poser 12 to upgrade.
Silverspider ( ) posted Wed, 30 September 2020 at 2:52 PM
Yes ghostship2, I had realised that and took the plunge! Now I'm discovering just how much Ive forgotten and how much I've missed. Like getting daz figures to show up in the poser content library and all sorts!
Rhia474 ( ) posted Wed, 30 September 2020 at 3:00 PM
Well, if you still have your old runtimes, all you have to do is re-add them. (This is why I keep them on an external drive).
Silverspider ( ) posted Thu, 01 October 2020 at 8:47 AM
yes I do Rhia474, they are on an external :)
Rhia474 ( ) posted Thu, 01 October 2020 at 11:06 AM
Then you can just reconnect them and everything, including DAZ figures should work fine, no need to reinstall?
