Thu, Sep 19, 8:40 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
Subject: Help!!!
deborahdavies ( ) posted Tue, 06 October 2020 at 4:53 AM · edited Thu, 19 September 2024 at 8:37 AM
I use psp pro and just bought 2020. I want to start using Poser also but havent b4. Once I become familiar and can use it, will I be able to save to png or jpg to use as part of designs I create in psp? Sorry if I sound a bit thick but I am a newby....
Thanks
Deb
infinity10 ( ) posted Tue, 06 October 2020 at 4:56 AM · edited Tue, 06 October 2020 at 4:57 AM
Yes you can export Poser renders as images. you can use these in your graphics software. The exported render formats are: PMG, TIF, BMP, TGA, JPG, PSD.
Eternal Hobbyist
seachnasaigh ( ) posted Tue, 06 October 2020 at 5:19 AM
If you are specifically aiming to use Poser output in PaintShopPro, you may be interested in rendering raster objects on a transparent background, like so:
deborahdavies ( ) posted Tue, 06 October 2020 at 5:36 AM
Thank you, that helps lots
Boni ( ) posted Tue, 06 October 2020 at 7:12 AM
Tip: if you plan on making images like seachnasaigh made 1. make the "construct" or GROUND not visable and 2. save as a png. To give you a head start. Have fun!!
Boni
seachnasaigh ( ) posted Tue, 06 October 2020 at 7:41 AM
Boni, that won't work for Superfly. You need to apply the holdout node as a material to the construct/ground/envirosphere to get a transparent background.
willdial ( ) posted Tue, 06 October 2020 at 8:09 AM
seachnasaigh, Boni's suggestion does work in Superfly. I used that exact technique to put in a sky with Photoshop just last week.
SamTherapy ( ) posted Tue, 06 October 2020 at 9:57 AM
Or, you can do what I do and get rid of the bleedin' Construct. :D
As for images, I always save 'em as PNG. Many of me textures are PNG these days, too.
randym77 ( ) posted Tue, 06 October 2020 at 10:00 AM
Works for me in Superfly as well. Thanks to a tip from someone here, I have my default Poser scene load with the ground prop set to visible, but not visible in camera. That way I can see it for posing (sometimes the grid is useful), but it doesn't render.
Miss B ( ) posted Tue, 06 October 2020 at 12:25 PM
SamTherapy posted at 1:24PM Tue, 06 October 2020 - #4401091
Exactly what I did when I first got P11, as I was so used to only having the default Ground plane to work with.
I just deleted it, and then re-saved my default scene without it. 😁
_______________
Butterfly Dezignz
