Wed, Nov 20, 7:41 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: A lot of the lighting nodes don't work
--- ( ) posted Mon, 02 November 2020 at 1:18 PM · edited Wed, 20 November 2024 at 7:30 AM
Is it just me or doesn't the Blinn node work in poser 12?
According to bagginsbill's post from 2010 "For 99% of materials, the best node to use is Blinn" @3708932 I use it a lot anyhow
I cant get Anisotropic or Phong nodes to work either. Glossy and ks_microfacet seems ok though. Here's what it looks like in the material room
ghostman ( ) posted Mon, 02 November 2020 at 1:28 PM · edited Mon, 02 November 2020 at 1:30 PM
Those should work in the firefly render engine. For Superfly the Cycles nodes have been updated to a newer version.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
bantha ( ) posted Mon, 02 November 2020 at 1:32 PM
True. BagginsBill's post was about Firefly shaders. Try to work with the Principled Shader BSDF and a Cycles root. you should be able to create very believable materials.
-"Amazing Grace" Hopper
--- ( ) posted Mon, 02 November 2020 at 1:44 PM · edited Mon, 02 November 2020 at 1:45 PM
Thanks!
Those nodes used to work fine in Poser 11 though. I guess i have some work to do
--- ( ) posted Tue, 03 November 2020 at 11:06 AM · edited Tue, 03 November 2020 at 11:06 AM
Ok I've just looked into my library... and its going to be quite a task. It would be nice if there was a script for the conversion
bagginsbill ( ) posted Tue, 03 November 2020 at 12:56 PM · edited Tue, 03 November 2020 at 12:57 PM
Ugh - there was benefit in using those even in SuperFly. The stupid color chips on the Cycles-specific nodes disappear when you plug something in. As do the numbers.
The FireFly style of parameter was better.
