Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
nerd posted at 9:49PM Mon, 02 November 2020 - #4402888
cpu and gpu produce slightly different results. That makes using them together unlikely. Multiple GPU is supported but obviously there's a bug.
So there is hope that I'll be able to use both of my cards at some point?
I tested rendered an old model at a very high resolution output. Poser 11 took longer using Dual GPU rendering. (About 14 minutes 50 seconds). If Poser 12 does use dual-card render I can't find the option. But using a single GPU card produced a faster render at around 8 minutes 18 seconds. However the lighting on the skin was different and produced no glossy highlights, in comparison to Poser 11.
I was hoping to be able to render faster but i'm a bit disappointed poser 12
vs old poser 11
dont see optiX but i see i cant use both cards at the same time.
I hope you can fix that, and even offert CPU + card1 + Card2 lets be crazy
