Sun, Nov 24, 6:43 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Cant render with both card
lsauvage ( ) posted Mon, 02 November 2020 at 3:54 PM · edited Sun, 24 November 2024 at 6:38 AM
I was hoping to be able to render faster but i'm a bit disappointed poser 12 image.png
dont see optiX but i see i cant use both cards at the same time.
I hope you can fix that, and even offert CPU + card1 + Card2 lets be crazy
nerd ( ) posted Mon, 02 November 2020 at 5:21 PM
Forum Moderator
cpu and gpu produce slightly different results. That makes using them together unlikely. Multiple GPU is supported but obviously there's a bug.
ghostship2 ( ) posted Mon, 02 November 2020 at 10:50 PM
nerd posted at 9:49PM Mon, 02 November 2020 - #4402888
So there is hope that I'll be able to use both of my cards at some point?
BernieFB ( ) posted Tue, 03 November 2020 at 2:18 AM
I tested rendered an old model at a very high resolution output. Poser 11 took longer using Dual GPU rendering. (About 14 minutes 50 seconds). If Poser 12 does use dual-card render I can't find the option. But using a single GPU card produced a faster render at around 8 minutes 18 seconds. However the lighting on the skin was different and produced no glossy highlights, in comparison to Poser 11.
lsauvage ( ) posted Tue, 03 November 2020 at 2:58 AM
Yes, i noticed that adaptive sampling reduce rendering time but it can destroy the image if set too high. I think that when the multi-card bug will be fixed, it will be better than poser 11 for rendering in superfly.
