Poser 12 F.A.Q (Last Updated: 2024 Aug 27 11:19 am)
You noted "(Checked Shadow_Catch_Only)" but I'm wondering if the shader needs to be otherwise black. (I don't have P12)
There's no telling how the feature was implemented. Maybe it's still adding the diffuse and specular reflections into the GI calculations.
I found the Shadow Catcher in Poser 12 reflects the light in the scene when it shouldn't.
Here is an example of the problem.
I created a scene that only has an HDR file in the Background material for the light source.
I set a square prop as the shadow catcher, (Checked Shadow_Catch_Only)
As you can see, Victoria is brighter like something beneath her is reflecting the light.
Here is the scene with the Shadow_Catch_Only unchecked.
When comparing the checked and unchecked images, Victoria is lit up the same.
Is there another way to setup the shadow catcher? If not, this is a serious bug and a big disappointment. A proper shadow catcher was the feature I really wanted.
