Thu, Nov 21, 8:21 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Why is Shadow Catcher Reflecting Light?
willdial ( ) posted Thu, 12 November 2020 at 9:50 PM · edited Thu, 21 November 2024 at 3:17 PM
I found the Shadow Catcher in Poser 12 reflects the light in the scene when it shouldn't.
Here is an example of the problem.
I created a scene that only has an HDR file in the Background material for the light source.
I set a square prop as the shadow catcher, (Checked Shadow_Catch_Only)
As you can see, Victoria is brighter like something beneath her is reflecting the light.
Here is the scene with the Shadow_Catch_Only unchecked.
When comparing the checked and unchecked images, Victoria is lit up the same.
Is there another way to setup the shadow catcher? If not, this is a serious bug and a big disappointment. A proper shadow catcher was the feature I really wanted.
ghostship2 ( ) posted Thu, 12 November 2020 at 10:25 PM
I've never used the shadow catcher. Is it an object?
willdial ( ) posted Thu, 12 November 2020 at 11:40 PM
It's a material setting applied to an object. In this case, a square prop. It's supposed to only catch the shadows in the scene. I use them all the time in Octane Render.
ghostship2 ( ) posted Thu, 12 November 2020 at 11:52 PM
OK. a couple of thoughts. 1 the square has shadows turned off so it's passing light up at your figure. 2 The square's normals are funky and that's why it passing light up at your figure.
willdial ( ) posted Fri, 13 November 2020 at 7:09 AM
The shadows are turned on and I get the same result with the High-Res Square or the Construct.
bagginsbill ( ) posted Fri, 13 November 2020 at 2:15 PM · edited Fri, 13 November 2020 at 2:16 PM
You noted "(Checked Shadow_Catch_Only)" but I'm wondering if the shader needs to be otherwise black. (I don't have P12)
There's no telling how the feature was implemented. Maybe it's still adding the diffuse and specular reflections into the GI calculations.
willdial ( ) posted Fri, 13 November 2020 at 5:23 PM
When I set the diffuse to black, the shadows disappear. I'm submitting a bug because shadow catcher is not working properly in Superfly.
