Poser scale is kind of screwy. Originally, it didn't have an official scale. Though "1 PNU = 8.6 feet" became official with Poser 6, a lot of people kept using the unofficial old scale of 1PNU = 8ft. I believe this is the scale DAZ used, and still uses.
For the average user, it probably doesn't matter, but if you're doing something where it does matter, it's probably best to check. Things like props, etc. may not be the size you think they are.
It all depends on the method you use for measuring scale. Using the measuring tool that comes with poser, she's 6'4" (76 in or 193 cm tall.)
Here's a copy of part of the ReadMe from my SXT 2000 model (on sale in RMP and you should all buy it because it's bloody good :D ) and what I have to say about scale:
Scaling:
Always a contentious matter in Poser; so I hope you find the following information helpful...
I built the models in Wings3d, using one square per inch. Imported to poser and scaled to 1.115%. This may seem like a strange size but it's the same scale as my Dalek freebies, and that scale was derived from Daleks made by Billy-home and Mechmaster, so it does have some precedent.
Taking the above, you could scale your figures - or scenery and props, as necessary - to the appropriate size using a known model that's built to a particular scale. For example, I use the scale of my amp and Dalek models as my base, and adjust other things in a scene so they look right. Mask-Da's guitars, ISTR, are a little smaller, so they get scaled up. If I was making a building with doorways, I'd use the general size of a UK door, which is 2 metres, or as near as dammit 6' 6".
By that reckoning, La Femme is way too big, Then again, V4 is ludicrously tall, too.
Definitely. I've had mixed results with scaling but I think I posted a height scale some time ago. Let me know if you need it again. SamTherapy posted at 5:13PM Sat, 14 November 2020 - #4404466
Scaling:
TwiztidKidd posted at 8:44PM Sat, 14 November 2020 - #4404619
Use one of her eyeballs as scale... it is known the human eyeball is 23.7 mm (sagittal, vertical) ... so stack a bunch of her eyeballs on top of each other and see how many you have... no pun intended lol
Wouldn't work if the eyes are scaled proportionally to the figure. You may get a correct height for the figure but it would only be for that figure and wouldn't relate in any meaningful way to anything else. It definitely wouldn't work with V4, since that model's eyes are disproportionately large anyhow. You'd need a universal scale, based on whatever you had already decided was a correct size for your Poser scenes.
Anyhow, it begs the question... Assuming La Femme is correctly proportioned, why the buggering chuff did Gabe make her so tall? Most women aren't that tall; in fact, most men aren't that tall, worldwide. Men in the UK average 6 feet, in the US, it's about 5' 10". Some North European countries have tall men and women but, by and large (pun not intended), women are generally smaller than men. Imagining La Femme in its default state as being yer average American female, she should come in at around 5' 6" at most.
Now, I'm not a tall guy; at best I was 5' 8", which was, at the time, the lower height limit for UK Firefighters. I didn't join 'em, as it happens, but I was accepted. Nowadays, old age, hard work and poverty have taken their toll and I'm around 5' 5" on a good day. Claire is 5' 8", which is quite tall for a woman, and the lady I was with before Claire was a rare - for a woman - 6' 1", and in her heels, around 6' 6". But, as I said before, that's rare. Mind you, it did mean I got a face full of boobies when we hugged, so it wasn't a bad deal at all. :D
Me point is, though, tall women ain't the usual thing. It's all well and good saying stuff about "Idealized" and whatnot but even artist's canons follow the guide that women, in general, are shorter than men, and men, as a rule are around 6 feet tall.
La Femme is the same height as Vicky 4. Who is really tall. But I don't think DAZ meant her to be 6'-4". DAZ uses the Dork = 6' tall scale. Vicky 4 is just a little shorter than Dork, so I think they meant her to be under 6'. Maybe 5'-11". Reasonable for a fashion model. There was also Stephanie, who is much shorter.
It's L'Homme who I find freakishly giant.
Changing the units to inches or cm doesn’t change the size of the things in the scene. It changes the controls. The x, y, and z trans change, some of the numbers in the material room change (not how they function but the numbers themselves) and some of the settings in the hair room change.
TwiztidKidd posted at 10:34AM Mon, 16 November 2020 - #4404748
So... I've stacked her eyeballs on top of each other LOL! I used 53.5 eyeballs which are 24 mm each in diameter meaning she stands 1284 mm or 4 feet 2 in tall.
Maybe I should stop eyeballing her
This was fun though...
If nothing else, it shows the scaling of figures in Poser is like the proverbial Madman's shite... all over the place.
randym77 posted at 3:01PM Thu, 19 November 2020 - #4405168
Great article, and table. No L'Homme, though. He's gigantic.
Thanks! I don't have L'Homme, but I've heard he's a big lad - even bigger than Dusk, anecdotally speaking. With notable exceptions, the history of Poser's figures has been a twenty-year growth spurt.
L’homme does have a size morph dial. He can be made smaller.
quietrob posted at 4:57AM Fri, 20 November 2020 - #4404604
Scaling:
Hey you! How have you been doing?
TwiztidKidd posted at 8:06AM Tue, 24 November 2020 - #4405625
Her eyeball is 1 inch and that's the new, more accurate PNU... You bring any character you want to any measuring scale u want, any 3D software you want, guess what... if they're human, their eyeballs are always going to be 1 inch... it's the Best constant you'll ever have for humanoid characters.
That's assuming the figure proportions are correct. I think your example shows that they are not.
G3's proportions are even more out of whack than V4's or LFm... she looks like a bobble head figurine and if you pose her hand close to her face you'll notice her hand is bigger than her entire face or head, not to mention her wrist looks like my ankle lol Some people wanted to import the entire G3 figure in Poser, I only wanted her head for the morphs and textures, so yeah... I did what I have to do to get just her head onto V4's body It's so much easier if you take her apart and you put her back in Poser lol you can call her FrankenPoserBarbie
randym77 posted at 5:56AM Tue, 01 December 2020 - #4405652
Yup. An adult human head is - ISTR - approx 8 inches from top to bottom. by approx 5 inches wide.
L'homme isn't really taller than Mike4 or Dusk. He's shorter. He loads scaled up to 110%. Look in the pose controls for the dial.
yes, the original la femme morph included the scaling. I'm sure it was added for compatibility with older clothing.
As the befuddled thread-starter, may I thank every-one who has contributed ?
"It depends..." was the result I'd feared, but that's life...
I download lots of eg MMD and Richard Mandel / DE free OBJ scenes+sets. Mega-poly-counts and import-scaling issues aside, each often has mildly conflicting heights for its seating, door-ways, stairs, ceilings and props. Add a Poser character who may stand anywhere from 5'6" to 6'6" and, V4 or LaF, the scene looks wrong, wrong, wrong. Sometimes iterating entire scene scale by a few percent will suffice. Sometimes XYZ scales need individual treatment. My DA render notes usually include wary proviso, 'Scaled by eye'...
I've acquired 'Balancer' which can 'intelligently' simplify mega-poly meshes. After years of struggling with a CAD program that only supported 'coloured' rather than 'textured' OBJs, and is worse than PP_11 with FBX, I think I've found a replacement. Also, now that P_12 seems to have settled as a stable release, that's on the buy-list, too...
Again, my thanks. N
ps: I'm still hoping P_12.n will add full 'Make Human' FBX rig compatibility....
Is there an official exact height for default La Femme, floor to no-hair scalp ?
Inches or cm, I'll happily convert...
I'm trying to match assorted OBJ etc imports, but other CAD programs, MMD etc have wildly different scaling factors. For example, a free DA 11-foot height bar for MMD shows a generic anime MMD figure as 5-feet-2, but I had to scale exported bar's OBJ to 3.50% in Poser for a LaF standing ~5-6...
