Thu, Jan 30, 7:38 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Poser 12 exporting render problem
722 ( ) posted Tue, 17 November 2020 at 9:54 PM · edited Thu, 30 January 2025 at 7:37 PM
I exported the render for the first time and it exported two. One I had in the render window but it exported an additional render called (original) below ill show the the render from render window then the second one that was designated original, and the the render from years ago from PP12.ProG p12.jpgProG p12_Original.jpgProG.jpg
ghostship2 ( ) posted Tue, 17 November 2020 at 9:57 PM
so..... what's the issue?
722 ( ) posted Tue, 17 November 2020 at 10:09 PM
Way is it exporting two renders? Is the lights acting different, i know the immitted object light would be different, but not the area lights???
randym77 ( ) posted Tue, 17 November 2020 at 10:14 PM
I think that happens if you have "apply post effects to render" checked. I think one is with post effects, one is without.
ghostship2 ( ) posted Tue, 17 November 2020 at 10:14 PM
because we now have post render effects, Poser exports one image with the effects and one without.
722 ( ) posted Wed, 18 November 2020 at 12:23 AM
What i never used that why was it on that means everything I've been rendering has been a not so as is, dang it.!
722 ( ) posted Wed, 18 November 2020 at 1:38 AM
how do you turn the post fx of the Super fly render always save two renders
randym77 ( ) posted Wed, 18 November 2020 at 5:13 AM
For me, having "Apply Post Effects to Render" (in Render Settings) checked means I get two renders exported. Unchecking it means I only get one.
722 ( ) posted Wed, 18 November 2020 at 5:58 AM
never checked that but stile get two renders.
ghostship2 ( ) posted Wed, 18 November 2020 at 9:39 AM
722 posted at 9:38AM Wed, 18 November 2020 - #4404983
Yes, it's bugged. the feature is set to "on" in new files even though it is not checked "on." You have to check it on then off again to turn it off.
722 ( ) posted Wed, 18 November 2020 at 11:25 PM
Yep its a Bugged, checking it on and off fix it, Thanks ghostship2.
gabrielxdesign ( ) posted Fri, 20 November 2020 at 4:16 PM
Yup, that Post FX thingy keeps turning itself on by itself. :/
ghostship2 ( ) posted Fri, 20 November 2020 at 5:36 PM
gabrielxdesign posted at 5:34PM Fri, 20 November 2020 - #4405292
It only does this for new files and ones you open from P11 or earlier. Once you save a file in P12 it wont turn the FX on unless you want them.
