Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
722 posted at 9:38AM Wed, 18 November 2020 - #4404983
never checked that but stile get two renders.
Yes, it's bugged. the feature is set to "on" in new files even though it is not checked "on." You have to check it on then off again to turn it off.
gabrielxdesign posted at 5:34PM Fri, 20 November 2020 - #4405292
Yup, that Post FX thingy keeps turning itself on by itself. :/
It only does this for new files and ones you open from P11 or earlier. Once you save a file in P12 it wont turn the FX on unless you want them.
I exported the render for the first time and it exported two. One I had in the render window but it exported an additional render called (original) below ill show the the render from render window then the second one that was designated original, and the the render from years ago from PP12.![ProG p12.jpg](https://live.cdn.renderosity.com/forum/threads/2954772/file_1d7f7abc18fcb43975065399b0d1e48e.jpg)
![ProG p12_Original.jpg](https://live.cdn.renderosity.com/forum/threads/2954772/file_96da2f590cd7246bbde0051047b0d6f7.jpg)
![ProG.jpg](https://live.cdn.renderosity.com/forum/threads/2954772/file_7e7757b1e12abcb736ab9a754ffb617a.jpg)
