Poser 12 F.A.Q (Last Updated: 2024 Nov 26 6:12 am)
are you getting any error messages? either pop-up or in the message log.
Uninstalled. Installed. Nothing shows up in window, yet in the "parameters" window the specs show up. The only error msg is from the DSON importer and these in msg box. 15:03:33 - Info: Your effective UI Scale factor is 1.00 15:09:19 - Application commands: Add figure(s) from library 15:10:59 - Application commands: Set render options 15:10:59 - Analytics: Recording event for Size:1229x770 15:10:59 - Analytics: Starting timer for Render:FireFly 15:11:04 - Firefly: Number of REYES objects: 95876 15:11:04 - Firefly: Number of micropolygons created: 0 15:11:04 - Firefly: Number of texture lookups: 0 15:11:04 - Firefly: Rendering time: 4.13 seconds. 15:11:12 - Firefly: Number of REYES objects: 150383 15:11:12 - Firefly: Number of micropolygons created: 178394 15:11:12 - Firefly: Number of texture lookups: 898622 15:11:36 - Firefly: Number of REYES objects: 150383 15:11:36 - Firefly: Number of micropolygons created: 1253854 15:11:36 - Firefly: Number of texture lookups: 622001 15:11:36 - Firefly: Rendering time: 32.24 seconds. 15:11:36 - Analytics: Ending timer for Render:FireFly 15:11:58 - Application commands: Delete figure 15:14:36 - Analytics: Recording event for Library:Michael 4 15:14:54 - Application commands: Add figure(s) from library 15:16:56 - Application commands: Delete figure 15:17:40 - Analytics: Recording event for Library:D3BL 15:17:50 - Application commands: Add figure(s) from library 15:18:59 - Analytics: Recording event for Library:Michael 5 15:18:59 - Analytics: Recording event for Python:Michael 5.py 15:19:00 - Application commands: Add figure(s) from library 15:20:15 - Application commands: Delete figure 15:21:02 - Analytics: Recording event for Library:Michael 4 15:21:28 - Application commands: Add figure(s) from library 15:22:19 - Analytics: Recording event for Library:Hiro 4 15:22:46 - Application commands: Add figure(s) from library 15:23:12 - Application commands: Delete figure 15:23:21 - Application commands: Delete figure 15:23:38 - Application commands: Delete figure 15:24:16 - Analytics: Recording event for Library:David 15:24:21 - Application commands: Add figure(s) from library 15:24:37 - Application commands: Delete figure.
Intel Quad CRU Q6600@2.4Ghz 4GB RAM AMD Radeon HD 6800 series
Just upgraded from 11. Opened 12 and tried to load Homme content. The panel says it is in the scene, but there is no figure in the window? All my libraries' content say they are loaded, yet nothing shows in my window. Been using Poser since #4 and have never encountered this. Suggestions?
