Tue, Nov 26, 5:16 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Loading character
zander ( ) posted Wed, 18 November 2020 at 12:45 PM · edited Tue, 26 November 2024 at 5:08 AM
Just upgraded from 11. Opened 12 and tried to load Homme content. The panel says it is in the scene, but there is no figure in the window? All my libraries' content say they are loaded, yet nothing shows in my window. Been using Poser since #4 and have never encountered this. Suggestions?
hborre ( ) posted Wed, 18 November 2020 at 2:13 PM
Are you actually loading the L'Homme character or just content? Your second sentence is a bit ambiguous. Elaborate further.
ChromeStar ( ) posted Wed, 18 November 2020 at 3:03 PM
Is it just out of view? Try switching to the posing camera. I've had that happen when a character isn't centered.
zander ( ) posted Wed, 18 November 2020 at 3:35 PM
Loading the L'Homme character. Am gonna try ChromeStar suggestion now. Thanks, so far.
zander ( ) posted Wed, 18 November 2020 at 3:38 PM
Just did posing camera. Still no character, sigh.
randym77 ( ) posted Thu, 19 November 2020 at 7:38 AM
Is it just L'Homme? Can you load other figures? V4, say, if you have her.
RedPhantom ( ) posted Thu, 19 November 2020 at 7:47 AM
Site Admin
are you getting any error messages? either pop-up or in the message log.
zander ( ) posted Thu, 19 November 2020 at 2:43 PM · edited Thu, 19 November 2020 at 2:46 PM
Uninstalled. Installed. Nothing shows up in window, yet in the "parameters" window the specs show up. The only error msg is from the DSON importer and these in msg box. 15:03:33 - Info: Your effective UI Scale factor is 1.00 15:09:19 - Application commands: Add figure(s) from library 15:10:59 - Application commands: Set render options 15:10:59 - Analytics: Recording event for Size:1229x770 15:10:59 - Analytics: Starting timer for Render:FireFly 15:11:04 - Firefly: Number of REYES objects: 95876 15:11:04 - Firefly: Number of micropolygons created: 0 15:11:04 - Firefly: Number of texture lookups: 0 15:11:04 - Firefly: Rendering time: 4.13 seconds. 15:11:12 - Firefly: Number of REYES objects: 150383 15:11:12 - Firefly: Number of micropolygons created: 178394 15:11:12 - Firefly: Number of texture lookups: 898622 15:11:36 - Firefly: Number of REYES objects: 150383 15:11:36 - Firefly: Number of micropolygons created: 1253854 15:11:36 - Firefly: Number of texture lookups: 622001 15:11:36 - Firefly: Rendering time: 32.24 seconds. 15:11:36 - Analytics: Ending timer for Render:FireFly 15:11:58 - Application commands: Delete figure 15:14:36 - Analytics: Recording event for Library:Michael 4 15:14:54 - Application commands: Add figure(s) from library 15:16:56 - Application commands: Delete figure 15:17:40 - Analytics: Recording event for Library:D3BL 15:17:50 - Application commands: Add figure(s) from library 15:18:59 - Analytics: Recording event for Library:Michael 5 15:18:59 - Analytics: Recording event for Python:Michael 5.py 15:19:00 - Application commands: Add figure(s) from library 15:20:15 - Application commands: Delete figure 15:21:02 - Analytics: Recording event for Library:Michael 4 15:21:28 - Application commands: Add figure(s) from library 15:22:19 - Analytics: Recording event for Library:Hiro 4 15:22:46 - Application commands: Add figure(s) from library 15:23:12 - Application commands: Delete figure 15:23:21 - Application commands: Delete figure 15:23:38 - Application commands: Delete figure 15:24:16 - Analytics: Recording event for Library:David 15:24:21 - Application commands: Add figure(s) from library 15:24:37 - Application commands: Delete figure.
Intel Quad CRU Q6600@2.4Ghz 4GB RAM AMD Radeon HD 6800 series
structure ( ) posted Thu, 19 November 2020 at 4:41 PM · edited Thu, 19 November 2020 at 4:41 PM
Forum Coordinator
does anything change if you alter these settings in the render settings panel?
Locked Out
zander ( ) posted Fri, 20 November 2020 at 10:53 AM
Tried altering render settings to no avail. Sigh. Probably should have tried the free trial before purchasing. Going to un then re-install without my prferences. Hopefully, that will work. Thank you for help.
zander ( ) posted Fri, 20 November 2020 at 12:31 PM
Evidently, 12 did NOT like my preferences. Re-installed without my pref. and can, now, load and see my "actor". Other than the DSON problem, it now works. Thank you all for replying.
