Thu, Feb 27, 12:09 AM CST
Subject: WIP, needs something
EricofSD ( ) posted Tue, 16 October 2001 at 11:53 PM · edited Sat, 01 February 2025 at 7:22 AM
Attached Link: http://www.annsartgallery.com/eric.htm
Lamp shade and base stand done in Metasequoia, rest is all Bryce. it needs something....
dcasey0284 ( ) posted Wed, 17 October 2001 at 12:51 AM
First, this looks pretty cool. Second, what is "metasequoia"? And third, how about a large stone fireplace on one side to give it more warmth...or a cylindrical aquariam tank that runs down through the ecnter of the sprial staircase? Just suggestions.
wgreenlee1 ( ) posted Wed, 17 October 2001 at 1:45 AM
what time period is this from??????
pnevai ( ) posted Wed, 17 October 2001 at 4:00 PM
My suggestions are that is needs more to loose stuff than anything new right now. The image is way too busy, to many conflicting textures and clashing colors. First make the floor a solid color try a gray or other cool color. You can apply a subtle bump to make it look like carpet. Next make the left wall match the color of the floor, a slightly lighter shade than the floor. Remove the texture from this wall. Try a smooth glossy surface for the lamp stands. I would move the staircase more toward the left rear corner, rather than leaving it in the middle of the room. The texture and color on the stairs is well, I don't know but you may wish to experiment with it a bit. Once you solve the texture overload. You will need an object as a center of focus for the scene. This could be a window, statue, work of art, something for the viewer to focus on. I am gathering that this is not a midevil setting as the lamps are rather contemporary.
EricofSD ( ) posted Sat, 20 October 2001 at 4:35 PM
Metasequoia is a freeware modeler at http://www1.sphere.ne.jp/mizno/main_e.html and I have a tut up at www.annsartgallery.com/eric.htm Will put up more.
SevenOfEleven ( ) posted Tue, 23 October 2001 at 1:58 PM
What is the theme of this picture? Is it a scene from an issue of "Better homes and gardens" or "Interior Design" or something else. Once you have a theme it makes it easier to know what fits and what does not.
