Mon, Feb 17, 7:36 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 17 1:20 pm)
Subject: Python 2 to Python 3
structure ( ) posted Sun, 08 November 2020 at 2:01 PM · edited Mon, 17 February 2025 at 7:33 PM
Forum Coordinator
via jennblake @4403050
We are currently working on quite a few scripts to update to python 3. We are working with the developers of previous scripts to get them working in Poser 12.
As was stated previously, implementing python 3 in Poser did break compatibility with a lot of the existing scripts, but please rest assured we are taking steps to get as many of those working in Poser 12 as possible.
Locked Out
Y-Phil ( ) posted Sun, 08 November 2020 at 2:19 PM
Great ?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Rhia474 ( ) posted Sun, 08 November 2020 at 2:23 PM
Thanks for the sticky, sir! <3
Miss B ( ) posted Sun, 08 November 2020 at 5:48 PM
Excellent news! 😁
_______________
Butterfly Dezignz
RobZhena ( ) posted Sun, 08 November 2020 at 6:49 PM
Is the developer of DSON one them (make or break for me on upgrading)? Netherworks?
structure ( ) posted Sun, 08 November 2020 at 11:35 PM
Forum Coordinator
Netherworks is in the pipeline
Locked Out
Miss B ( ) posted Mon, 09 November 2020 at 12:02 AM
structure posted at 1:01AM Mon, 09 November 2020 - #4403939
YAY!!! I have, and use, so many of his goodies, I'm thrilled to hear he's going to be updating his scripts. 😁
_______________
Butterfly Dezignz
RedPhantom ( ) posted Mon, 09 November 2020 at 12:15 PM
Site Admin
Since it's open-source now, I was wondering if anyone was thinking about updating reality. I'm not sure how many people still use it, but I imagine there ate a few.
blackbonner ( ) posted Tue, 10 November 2020 at 1:30 AM
I use Sasha for V4 and the Lali Addon from Erogenesis, both are dependent on Python Script if i am not mistaken. I have tested them both in Poser 12 latest version and they seem to work properly. Just in case someone is interested.
hborre ( ) posted Tue, 10 November 2020 at 10:27 AM
If you have characters already created prior to P12 then they will work. However, the script to create the base Sasha-16 does not work. Other scripts are hit or miss.
blackbonner ( ) posted Tue, 10 November 2020 at 11:37 AM
Hm, thats odd! I got a fresh runtime, only original files, not tempered at all and Sasha 16 works. I open up the characters folder and follow the steps like it states inside the folder. V4 loads and gets morphed... I'm not an expert but this is made with Python Script, right? Same goes for Lali by Erogenesis. Correct me if am wrong.
CHK2033 ( ) posted Tue, 10 November 2020 at 12:06 PM · edited Tue, 10 November 2020 at 12:12 PM
Are you sure the scripts are actually working ? its V4 so she might load up regardless, I loaded her up as well (Sasha) but I didn't check to see if what the scripts do or improve are actually functioning or not on her. (note I didnt install her in Poser 12 shes in Poser Pro 2014 I used a linked runtime of her already saved out in PP2014 with all the bells and whistles to bring her into Poser 12)
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
blackbonner ( ) posted Tue, 10 November 2020 at 12:23 PM
I only have Poser 12 on my computer and the runtime is about 24 hours old, just as the OS. I thougt after purchasing Poser 12, it would be a good idea to make a cut and a fresh start. I will create a scene in Poser 12 with Sasha 16 to test if the alterations of the V4 figure worked. I post the results tomorrow.
hborre ( ) posted Tue, 10 November 2020 at 12:52 PM
I have two installs of Sasha-16, the original and the 2019 edition. The original loads V4, the 2019 edition flags an error.
blackbonner ( ) posted Tue, 10 November 2020 at 1:25 PM
@hborre Im right now working with the sasha 16 version 2019. What funktion flags the error?
blackbonner ( ) posted Tue, 10 November 2020 at 1:27 PM
I have only the 2019 Version, maybe this is causing the error?
blackbonner ( ) posted Tue, 10 November 2020 at 1:31 PM
The bending and the weight mapping/Joint alterations seem to work so far. Also the genital is were it belongs. No complains on my side.
hborre ( ) posted Tue, 10 November 2020 at 1:32 PM
Never had a problem under P11 but it could be a potential. I'm going to transfer the SASHA-16 2019 files to a second P12 install on another computer to check.
hborre ( ) posted Tue, 10 November 2020 at 1:45 PM
This is the error I get with the 2019 edition:
hborre ( ) posted Tue, 10 November 2020 at 2:09 PM
Okay, I figured it out. Apparently, I needed to copy over all the Python Scripts from my P11 Python Folder to the P12 Python Folder. Everything is all good now. SASHA-16 2019 Edition works.
blackbonner ( ) posted Tue, 10 November 2020 at 2:20 PM
@hborre Stupid question, are you working on windows or apple?
blackbonner ( ) posted Tue, 10 November 2020 at 2:32 PM
Poser 12 and Sasha-16 2019 edition Character folder.jpg The only button that produces the error you mentioned, is the "INJECT The DAZ Morphs". I thought this was a function dedicated to DAZ STUDIO, so i never used it. Ah, i see, you managed to work it out.
Y-Phil ( ) posted Tue, 10 November 2020 at 3:57 PM
In fact, such popup message appears when a Poser file tries to launch a Python script that can't be found. In this case, it's a CR2 file which contains: runPythonScript "runtime:Data:! Karina:html:SETUP:ILH 2.2.py"
And the python file "ILH 2.2.p" isn't under "....:html:SETUP" but, in my case under "...:Inline Help:" Note that I have kept only one runtime, with both editions.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CHK2033 ( ) posted Tue, 10 November 2020 at 3:58 PM
hborre posted at 3:57PM Tue, 10 November 2020 - #4404129
** Apparently, I needed to copy over all the Python Scripts from my P11 Python Folder to the P12 Python Folder. **
So do you think this would work for some other things which used the older script as well ?
grichter ( ) posted Wed, 11 November 2020 at 10:51 AM
I am on a Mac. They say Poser 12 for Mac will not be released until sometime in December. On the Python website the have a script called 2to3 that is supposed to either convert or help with the conversation of Python 2 scripts to work under Python 3. Anybody tried this?
I have a lot of scripts I purchased, freebees or wrote myself that I use constantly. Without them I would be lost.
Gary
nightsong ( ) posted Thu, 19 November 2020 at 1:23 PM
Is there any news on whether Semidieu's scripts (esp Advanced Render Settings 2) or the DSON importer will work in Poser 12? (So glad to hear Netherworks is on the job!)
hborre ( ) posted Thu, 19 November 2020 at 3:40 PM
https://www.renderosity.com/rr/mod/forumpro/?thread_id=2954792
I discovered a workaround for getting Genesis 8 into P12 that involves using DSON in P11 and resaving the CR2 back into the Library. If you have P11 and DSON, follow the link and read on.
nightsong ( ) posted Thu, 19 November 2020 at 4:40 PM
Thank you!! That helps!
I haven't invested in Poser 12 yet because I need those two things badly for projects I'm working on, and I've come to rely very badly upon the library of scripts I've gotten over the years for everything else. Without having -at least- selective item/layer render passes, magnet toy, morph imp, and GS2/3/8 imports (as well as heaven knows how many mini-pythons included with other products), I'd essentially be paying for a downgrade as far as my personal workflow goes. :( I'm especially concerned, and looking forward to hearing more, about cross-compatibility with these older scripts or surrogate support for those python utilities originating from content creators that have retired from the 3D marketplace.
JoEtzold ( ) posted Sat, 21 November 2020 at 11:46 AM
Any ideas about Dimension3D's fine Python scripts ? These are sold up to now here in MP although he past away much to early in ever reason ... :-(
randym77 ( ) posted Sun, 22 November 2020 at 7:08 AM
JoEtzold posted at 7:07AM Sun, 22 November 2020 - #4405415
Someone said Bondware had permission from his heirs to update his scripts, and they were working on it.
JoEtzold ( ) posted Sun, 22 November 2020 at 11:26 AM
Okayyyy, as ever "Green is the Hope" ... so may it green/grow for long with a good ending ... :-))
Miss B ( ) posted Sun, 22 November 2020 at 12:59 PM
randym77 posted at 12:58PM Sun, 22 November 2020 - #4405482
That's good news too, as I have a number of Ralf's goodies as well.
_______________
Butterfly Dezignz
creed2003 ( ) posted Mon, 23 November 2020 at 7:17 PM
Would this affect Reality working in Poser 12? I’m unable to get it to work.
structure ( ) posted Tue, 24 November 2020 at 11:48 AM
Forum Coordinator
creed2003 posted at 11:47AM Tue, 24 November 2020 - #4405621
Have you tried AVFIX by Snarlygribbly?
Locked Out
Snarlygribbly ( ) posted Wed, 25 November 2020 at 8:34 AM
AVFix is for Poser 11 only, and wouldn't help with Reality in Poser 12 anyway - Reality has a compiled .pyd file that needs to be recompiled from the original source files.
Free stuff @ https://poser.cobrablade.net/
creed2003 ( ) posted Wed, 25 November 2020 at 12:16 PM
Snarlygribbly posted at 12:15PM Wed, 25 November 2020 - #4405726
So basically what your telling me is at this point Reality doesn’t work in Poser 12?
RAMWorks ( ) posted Thu, 03 December 2020 at 10:08 AM
Wasn't aware of Ralf's scripts being updated. COOL!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
Vaskania ( ) posted Mon, 14 December 2020 at 6:50 PM
Came across a fairly new python library in my travels called Six to aid as a compatibility layer so single scripts can be compatible with both python 2 and 3 without the need for multiple versions of the scripts. It's got an MIT license and can be included with projects. Here's the link if anyone feels it can be of use: https://pypi.org/project/six/
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
RAMWorks ( ) posted Mon, 14 December 2020 at 7:20 PM
KEWL. Thanks so much Vaskania! 😁
My Store is HERE
Darktoz ( ) posted Sun, 20 December 2020 at 11:51 PM
Nothing does work anymore.
Most stuff from renderotica: Forget it!
The overlay stuff from this site like tattoos from shana or the lululee clothing overlays: Forget it.
I doubt that you will get a lot of the old stuff to work.
The only thing that I got working was Darkworld's overlays. Don't know why.
Horrible experience, very frustrating. Will go back to Poser 11.
WandW ( ) posted Sun, 10 January 2021 at 7:44 AM
Snarlygribbly posted at 7:40AM Sun, 10 January 2021 - #4405726
Reality is now open-source...
SourceForge: Reality Plugin/Code
CobraBlade ( ) posted Fri, 29 January 2021 at 7:43 PM
I guess the good news is Poser 12 is now available for Mac so I can jump in any time now, but I still wanted to wait until there is a version of EZSkin that'll run in 12. Did anyone know if @SnarlyGribbly has made any progress? All I could find was this article
Poser scripts by Snarlygribbly
hborre ( ) posted Fri, 29 January 2021 at 8:45 PM
Nothing new has been developed yet. We're still waiting.
CobraBlade ( ) posted Sat, 30 January 2021 at 7:06 PM
Thanks for the update @hborre, I'll continue to hold off for now then.
722 ( ) posted Sun, 31 January 2021 at 7:18 PM
is easy skin for P12 close to being complete
hborre ( ) posted Mon, 01 February 2021 at 8:59 AM
I am presuming that part of the problem why EZSkin hasn't been released just yet is that P12 is still having growing pains, so to speak. There are P12 nodes that have been broken for a long time and are being corrected now by the Tech Team, and nodes that are inadvertently getting broken because of making corrections. Until such a time that everything is finalized and working properly, we won't see EZSkin on the market any time soon. So don't uninstall P11 yet and keep an eye on any EZSkin shaders generated for P12 use; anything that may look correct in P11 may not absolutely look correct in P12.
