Sun, Nov 24, 10:41 AM CST
Subject: Collada or FBX export for Poser 11 does not export surfaces for Props
dompie ( ) posted Sat, 28 November 2020 at 12:21 PM ยท edited Fri, 01 November 2024 at 8:46 AM
Hi,
I am using Poser 11 PRO (v11.3.740) and looking into exporting a Poser scene to Ligthwave (2018). (I am considering buying Poser 12 but it seems Fusion is no longer part of the product so I must find another way of importing Poser scenes into LW). I've tried FBX and Collada but both seem to have the same problem: the figures are exported correctly but the surfaces are lost on the props. E.g. I exported the "OliveHair" prop which in Poser has about a dozen of surfaces. After import in LW, it has only one. When I re-import the collada file into Poser (so the one Poser exported itself), I have the same issue: there is just one surface Is this a bug in the collada exported in Poser? Any help much appreciated
Nagra_00_ ( ) posted Sat, 28 November 2020 at 4:00 PM
This is a bug in Poser. FBX and Collada export of props exports without UV map and materials. I mentioned this when Bondware dropped support for Poser Fusion saying that we could use FBX instead, but that's not true.
caisson ( ) posted Sat, 28 November 2020 at 7:30 PM
I just exported a multi-part Merlin prop set from Poser 12 via FBX and imported to Lightwave 2020. Also tried a figure - Mysthero's CBR1100X - and though it's not perfect (couple of minor textures, reflection maps, missed and the front fork on the cycle is in the wrong position as the figure is not zeroed) - UV's, textures and surfaces are working.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
