Sun, Dec 1, 12:14 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: Renderin Out talking animation in Poser 11 with Transparent background
saibabameuk ( ) posted Wed, 16 December 2020 at 5:00 PM · edited Fri, 29 November 2024 at 8:47 AM
Rendering for a transparent background, help please. Wish to Render out talking animation in Poser 11 any ideas of the setting I would need ? I end up with a grey, but need it to export into final cut as a transparent background.Screen Shot 2020-12-16 at 17.23.24.png
Richard60 ( ) posted Wed, 16 December 2020 at 6:26 PM
I don't believe you can render a transparent background with any of the movie making Codexs. What you need to do is render to frames and select a format that supports transparency, such as TIFF. Then in Final Cut import your frames and make each frame 1/30 of a second long and apply your background on another layer. OR try a background such as a bright Green and do a Chroma Key in Final Cut.
saibabameuk ( ) posted Thu, 17 December 2020 at 4:32 AM
Thank you is interesting perhaps a project for the BETA testers on the new Poser 12? Yes PNG seems the only way , I take them into Motion grouping them then add the voice in Final Cut. The green will work as I posted I thought yes a green back ground. Then take that out in Final Cut, bu this should not need to happen in an advanced animation programmed, like Poser, do you agree ?SaiTalk2.0003.png
saibabameuk ( ) posted Thu, 17 December 2020 at 8:54 AM
OK the green screen is the best quality so far/ PNG you can get miss match on the voiceScreen Shot 2020-12-17 at 14.34.44.png
Richard60 ( ) posted Thu, 17 December 2020 at 4:57 PM
The problem is not in Poser it has to do with the file formats in the Movie codexs. The Movie formats are normally the final product in a production chain. Therefore they tend to only keep the data that is important to convey the images. That does not include the the Alpha/Transparency information.
If your sound is getting out of sync either A you are using a very long clip or B the compression on the Audio is not being decoded at a fixed rate. It could also be that you made the clip in Poser and that is hard set to be 30 frames a second and that in Final Cut it is using 24 frames.
saibabameuk ( ) posted Thu, 17 December 2020 at 5:45 PM
Yes quite right on all your facts, and thank you for coming back to me. After a very long 7 hour Render I have my words and image. With the green background working perfectly. So tomorrow , will go through the same endurance (render process) the main thing is it's working. Thanks all.
