Thu, Jan 30, 7:16 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: SuperFly doesn't work
MNE ( ) posted Wed, 23 December 2020 at 8:12 AM ยท edited Wed, 15 January 2025 at 4:51 PM
Please help. Although it is POSER12.0.323, it can be rendered well on the CPU, but the background image cannot be rendered on the GPU.3.jpg
ghostship2 ( ) posted Wed, 23 December 2020 at 8:43 AM
I could get an imported background to render with the image (GPU) but could not get the render dimensions to match the background image. I've never used render over background in that way so I'm probably the wrong guy to ask. What I do is load an HDRI onto the background in the mat room and use it as the lighting for the scene. Make sure you make the construct invisible in your hierarchy. backgroun lighting.jpgbackground lighting 2.jpg
Y-Phil ( ) posted Wed, 23 December 2020 at 3:51 PM
ghostship2 posted at 3:50PM Wed, 23 December 2020 - #4408291
Shanghai bund gives an interesting lighting... ๐Ÿ˜„
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
ghostship2 ( ) posted Wed, 23 December 2020 at 4:21 PM
MNE ( ) posted Fri, 25 December 2020 at 1:47 AM
I was surprised that what I could do with POSER 12.0.306 can no longer be done with POOSER 12.0.332. This isn't just my symptom, so I hope it will be cured someday.
722 ( ) posted Fri, 25 December 2020 at 3:01 AM
There at P12.0.340.
ghostship2 ( ) posted Fri, 25 December 2020 at 12:05 PM
722 posted at 12:03PM Fri, 25 December 2020 - #4408471
There at P12.0.340.
I only see Beta P12.0.336 at this point and again that is beta so not something everyone has access too.
ghostship2 ( ) posted Fri, 25 December 2020 at 12:19 PM
import background works and renders in both CPU and GPU on Beta 12.0.327. I'll load the latest beta and test.
ghostship2 ( ) posted Fri, 25 December 2020 at 3:08 PM
Beta 12.0.336 imports and renders background image just fine. Tested CPU, OPTIXGPU, GPU. no problems encountered. This issue must be with your specific machine or setup.
Y-Phil ( ) posted Fri, 25 December 2020 at 6:34 PM
ghostship2 posted at 6:33PM Fri, 25 December 2020 - #4408511
There at P12.0.340.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
ghostship2 ( ) posted Fri, 25 December 2020 at 7:04 PM
I don't know why Beta has a lower number than working copy of Poser 12. I'll have to ask.
MNE ( ) posted Sat, 26 December 2020 at 2:21 AM
I confirmed that background images can also be rendered with POSER 12.0.340. Thank you for your quick fix.1_Original.jpg
Richard60 ( ) posted Sat, 26 December 2020 at 10:24 AM
@ghostship2 The build number keeps incrementing each day/build, even if nothing is changed. So we may have 336 and when it is posted to the public it gets the newer number. At least that is how it was explained to me.
ghostship2 ( ) posted Sat, 26 December 2020 at 12:29 PM
@Richard60 ok makes sense!
