Sat, Jan 4, 10:46 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Subject: La Femme Morph Needs Fixing.
bwldrd ( ) posted Mon, 28 December 2020 at 9:12 PM · edited Thu, 02 January 2025 at 4:39 PM
Not sure where to post this, so sorry if in wrong forum.
I'm having a problem with the LaFemme MouthWidth morph when set to -1 (to narrow the mouth). Screenshot highlights the problem.
Any chance of getting a fix for this?
Consider me insane if you wish, but is your reality any better?
-renapd- ( ) posted Tue, 29 December 2020 at 1:30 AM
Site Admin
Morphs are not supposed to be used at negative values for any figure. Negative settings (since not what the morph was created for) usually give distortions. Try mouth narrow instead rather than mouth width set to negative values.
[[MyGallery] [MyStore]
"Collect moments, not things."
bwldrd ( ) posted Tue, 29 December 2020 at 2:22 AM
There is no "mouth narrow" morph only the MouthWidth with dial limitations of -1 to 1. Since LaFemme uses limits, and the minimum for this morph is -1. I am under the assumption that it is to be used as a wider/narrow functionality.
-renapd- ( ) posted Tue, 29 December 2020 at 9:38 AM
Site Admin
Still negative values are not a standard.. I would suggest you use it not fully at -1 but -0.8 or -0.9 by typing the input rather than using the dial itself. The results will be far better. What you're showing is extreme and visible only at HQ closeup so I think that might work for you.
Y-Phil ( ) posted Tue, 29 December 2020 at 11:43 AM
bwldrd posted at 11:41AM Tue, 29 December 2020 - #4408846
La Femme, as installed by default with Poser 12, has poses dials. If you activate them, you may narrow her mouth this way?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
