Poser 12 F.A.Q (Last Updated: 2025 Jan 19 10:19 am)
There is no "mouth narrow" morph only the MouthWidth with dial limitations of -1 to 1. Since LaFemme uses limits, and the minimum for this morph is -1. I am under the assumption that it is to be used as a wider/narrow functionality.
Consider me insane if you wish, but is your reality any better?
Still negative values are not a standard.. I would suggest you use it not fully at -1 but -0.8 or -0.9 by typing the input rather than using the dial itself. The results will be far better. What you're showing is extreme and visible only at HQ closeup so I think that might work for you.
[[MyGallery] [MyStore]
"Collect moments, not things."
bwldrd posted at 11:41AM Tue, 29 December 2020 - #4408846
La Femme, as installed by default with Poser 12, has poses dials. If you activate them, you may narrow her mouth this way?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Not sure where to post this, so sorry if in wrong forum.
I'm having a problem with the LaFemme MouthWidth morph when set to -1 (to narrow the mouth). Screenshot highlights the problem.
Any chance of getting a fix for this?
