Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 10:25 am)
Oh, and yes, you read it right, V2. Not V3, V4, or any other iteration.
I had made some .pz2 files years ago to make Mike2's hands bigger so I just replaced the values and made you some more. If you need them smaller then you'll have to edit the .pz2 file. I used Edit Pad Lite and it's just a simple matter of adding the value and the one to replace it with and it replaces all instances in one go - much better than fiddling in Poser :) Here's the link: https://www.dropbox.com/s/8vd96rld00tbn84/handsscale.zip?dl=0
Hmm, looks like all his Rendo Freestuff links are broken?
The direct link from his website still works, though:
Ta for the link to Anthony's stuff. I decided to use that one, since I'm a lazy bugger. :)
Not just the hands, obviously, but the fingers, too. I made a petite character and the hands are now like snow shovels. Short of selecting each and every single bleedin' finger joint, I can't figure out a way to do it, and it's a real pain in the bottom.
