Tue, Nov 26, 8:26 AM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 24 8:35 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Helpful Tip for Free Stuff Uploaders (Daz Studio)
Heatherlly ( ) posted Tue, 01 September 2020 at 2:31 AM · edited Mon, 25 November 2024 at 7:42 PM
As a Free Stuff tester, the most common issue I run into is missing files. This can happen even when the uploader has carefully tested their product – all files are present in their library, so they can't always tell if they've left one out of their zip file.
A simple solution is to use a test library. All you have to do is create a new folder on your computer, then add it as a base directory in Daz Studio:
Once you've created the directory, put the contents of your zip file in there. It's important to use the same folder structure you would in your regular library (data, people, props, runtime, etc.).
With a separate directory, you can test your item and find out exactly what's missing (if anything). It won't pull files from your main library – it's basically like a clean install.
Hope you find this helpful! Please let me know if you have any questions.
Heatherlly (Daz3d Coord)
hborre ( ) posted Tue, 01 September 2020 at 7:55 AM
Practical tip, thank you.
Oldminer ( ) posted Thu, 05 November 2020 at 10:00 AM
How do I submit an Freebie for review.? Do I use a New Post and should I use a zip file? I am setting up a test area as indicated in your post.
Torquinox ( ) posted Mon, 07 December 2020 at 8:56 PM
Good idea. Thanks.
barbzthorpe ( ) posted Sat, 09 January 2021 at 11:16 AM
Brilliant idea, cos I was thinking of giving some freebies back to the Renderosity communiy.
Cheers!
