Tue, Jan 14, 9:10 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 14 5:11 pm)
Subject: Moving from Poser 10 to Poser 12, help!
crystalmethodcaf ( ) posted Tue, 12 January 2021 at 9:30 AM · edited Tue, 14 January 2025 at 9:04 PM
I bought Poser 12 because of the promise for faster renders and the render queue. However, working in it, I've already ran into some problems I could use some help with!
  1. My V4 is green/gray! I was able to offset this with the Gamma Correction settings with Firefly in Poser 10 (just unchecking it), but I'm not seeing that option for Superfly. How can I fix her skin? It even looks like this in the preview window. Poser 12, SuperFly: Test_0565.png
Poser 10, preview and Firefly: Text2.png
  1. I was able to create custom designs on clothing by setting it as the diffuse color in Poser 10's material room, but now whenever I go to the Materials tab in Poser 12, it's just nodes. How can I achieve this same functionality?
Y-Phil ( ) posted Tue, 12 January 2021 at 9:56 AM
I'm surprised by the result, I mean: I've been using vic4 characters since such a long time... Have you specific gamma settings for your bitmaps? Don't forget that superfly is a pbr
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
randym77 ( ) posted Tue, 12 January 2021 at 9:57 AM · edited Tue, 12 January 2021 at 9:59 AM
You can still use the Firefly renderer in Poser 12. It's on a different tab in Render Settings.
Some textures look greenish or muddy in newer versions of Poser. There's a script called EZskin that a lot of us used to fix that. It's still being adapted to Poser 12, though. You can instead the diffuse color to white manually. (Usually if you go into the Material Room and check, there's a greenish color in Diffuse Color.)
You should still be able to use diffuse colors and textures in Superfly. The node may be collapsed, but if you click on it and expand it, it's similar to Firefly.
crystalmethodcaf ( ) posted Tue, 12 January 2021 at 10:40 AM
I don't recall any gamma settings. I did find the Diffuse color issue randym mentioned, but I was hoping I wouldn't have to manually do that every time I start a new scene... maybe that's what the EZskin is for. But changing it there to blue made it look right.
Now I've ran into another major gripe - We can't send movies to the Render Queue?!?!?!?!?! That was like 95% of the reason I upgraded!
randym77 ( ) posted Tue, 12 January 2021 at 10:50 AM
Yes, EZSkin makes it really quick and easy. You just choose your figure, choose between Firefly and Superfly, and click. I know Snarly's working on updating it (some material nodes need to be changed). It's possible to get old scripts to work in Poser 12, but I haven't checked to see if EZSkin is one of them. (I have Poser 11 as well as Poser 12, and just use Poser 11 when I want to run a script.)
Not all textures have the green tinge problem. I think it was something some vendors did to try and fake SSS. It's not necessary with newer versions of Poser, and just looks weird. But you shouldn't have to fix every skin texture.
hborre ( ) posted Tue, 12 January 2021 at 6:26 PM
Once EZSkin P12 becomes available, that problem will become history. The blue diffuse chip color was a hack along with the activated red ambient channel to fake SSS. So I wouldn't rely upon any default shaders developed before P11.3/P12. Also, pay attention to node connections that are dashed rather than solid. The current iteration of Poser can detect bad or 'illegal' connections between nodes, causing Poser to render your models incorrectly or at all.
