Fri, Jan 10, 9:12 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: [File]-[Run Python Script] issue?
jadeite123 ( ) posted Sat, 16 January 2021 at 5:36 AM · edited Fri, 10 January 2025 at 9:06 PM
When I run a script with [File]-[Run Python Script] on the Windows version of 12.0.340, I get an error.
It seems that the error occurs depending on the pathname.
D:\usr\poser\scripts\test.py
import sys
print(sys.version)
Results
File "", line 1
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated uXXXX escape
3.7.9 (tags/v3.7.9:13c94747c7, Aug 17 2020, 18:58:18) [MSC v.1900 64 bit (AMD64)]
Is "\usr" in the pathname interpreted as an escape in the internal process....?
Changing the pathname to "D:\poser\scripts\test.py" works fine.
adp001 ( ) posted Sat, 16 January 2021 at 6:24 AM · edited Sat, 16 January 2021 at 6:24 AM
Same error if you write
print("Something")
a line before
import sys
If not, "sys.version" seems to return a bytearray and "print" cant use that as is.
(Can't check it myself because no P12 here)
jadeite123 ( ) posted Sat, 16 January 2021 at 6:50 AM
adp001 posted at 6:39AM Sat, 16 January 2021 - #4410436
print("Something")
Thank you for your response.
I tried as follows.
script
print("!!! test !!!")
import sys
print(sys.version)
Results (D:\usr\poser\scripts\test.py)
File "", line 1
!!! test !!!
Results (D:\poser\scripts\test.py)
!!! test !!!
The results are the same as before.
FVerbaas ( ) posted Sat, 16 January 2021 at 8:44 AM · edited Sat, 16 January 2021 at 8:45 AM
Forum Coordinator
As code it works fine for me from a location with similar path.
Solution: Try to copy your code to notepad and save from there in a new file.
I have had similar issues with code I copied from a conversation in Slack. In my case that had left some non-printable chacarcters. Notepad is not sophisticated enough to deal with those so it just filters them out.!
jadeite123 ( ) posted Sat, 16 January 2021 at 10:15 AM · edited Sat, 16 January 2021 at 10:21 AM
FVerbaas posted at 9:57AM Sat, 16 January 2021 - #4410453
I created a new script by copying and pasting on Notepad, but the trouble was not solved.
D:\usr\poser\scripts> type test.py         * <- old script
import sys
print(sys.version)
D:\usr\poser\scripts> type test2.py        * <- new(copied) script
import sys
print(sys.version)
D:\usr\poser\scripts> fc /b test.py test2.py
Comparing files test.py and TEST2.PY
FC: no differences encountered
D:\usr\poser\scripts> certutil -dump test.py
  0000  ...
  0037
    0000  70 72 69 6e 74 28 22 21  21 21 20 74 65 73 74 20   print("!!! test
    0010  21 21 21 22 29 0d 0a 69  6d 70 6f 72 74 20 73 79   !!!")..import sy
    0020  73 0d 0a 70 72 69 6e 74  28 73 79 73 2e 76 65 72   s..print(sys.ver
    0030  73 69 6f 6e 29 0d 0a                               sion)..
CertUtil: -dump command completed successfully.
Results (D:\usr\poser\scripts\test2.py)
File "", line 1
!!! test !!!
Results (D:\poser\scripts\test2.py)
!!! test !!!
That seems to be a problem that depends on my environment.
I would like to solve it by using "D:\poser\scripts".
