Sun, Jan 5, 1:02 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: Clothing distorting with character morphs
DreamWeaver_Designs ( ) posted Mon, 18 January 2021 at 3:35 PM · edited Fri, 03 January 2025 at 3:17 PM
This is the hooded robe from the Iconic MFD bundle 2 one G8F with the character morph Eryn applied, though it does this with some others too. As you can see it is getting a bit messed up round the hip, has anyone got any idea how to fix this please? I have done the show hidden properties thing to see if something needed zeroing but everything is already zeroed.
Liquid_Ice ( ) posted Wed, 20 January 2021 at 9:20 AM
It looks like one of the bones in the dress is bored. Maybe look at the rigging/weight maps?
DreamWeaver_Designs ( ) posted Wed, 20 January 2021 at 12:17 PM
Liquid_Ice posted at 12:16PM Wed, 20 January 2021 - #4410769
I did that and everything looks like it lines up as it should
Liquid_Ice ( ) posted Wed, 20 January 2021 at 4:04 PM · edited Wed, 20 January 2021 at 4:04 PM
Lol I meant borked.. Autocorrection. It is only with this character set? I haven't encountered this myself. Have your tried to change the rigging to adjust to the shape?
DreamWeaver_Designs ( ) posted Wed, 20 January 2021 at 4:16 PM
Liquid_Ice posted at 4:12PM Wed, 20 January 2021 - #4410793
Lol I meant borked.. Autocorrection. It is only with this character set? I haven't encountered this myself. Have your tried to change the rigging to adjust to the shape? I got what you meant lol. There are a few others that do this to some extent or another, Aiko, Karyssa, Mika from memory possibly some others too. How do mean change the rigging to adjust the shape?
Liquid_Ice ( ) posted Wed, 20 January 2021 at 4:37 PM
Normally if you make a cusorm morph, the rigging is off. There is a feature in Daz that corrects the joints automatically. You can do that with clothes too. Probably doesn't work but wirth a try. It's on the second menu ( I'm not at my computer) and there is an option for figure and rigging. You can find it there.
DreamWeaver_Designs ( ) posted Wed, 20 January 2021 at 5:09 PM
Liquid_Ice posted at 5:08PM Wed, 20 January 2021 - #4410797
Normally if you make a cusorm morph, the rigging is off. There is a feature in Daz that corrects the joints automatically. You can do that with clothes too. Probably doesn't work but wirth a try. It's on the second menu ( I'm not at my computer) and there is an option for figure and rigging. You can find it there. Sounds interesting, will have a look and see if I can work it out when I can get back into DS (doing backups lol)
Liquid_Ice ( ) posted Fri, 22 January 2021 at 4:02 PM
lemme know if it worked. I dont think it will but at least you tried. If not we have to find another solution :)
Liquid_Ice ( ) posted Fri, 22 January 2021 at 4:03 PM
you can also unparent it and autofit it, see if that solves the problem.
DreamWeaver_Designs ( ) posted Fri, 22 January 2021 at 7:56 PM
Liquid_Ice posted at 7:55PM Fri, 22 January 2021 - #4410887
lemme know if it worked. I dont think it will but at least you tried. If not we have to find another solution :) Will do. I got sidetracked by shifting everything to another computer then a render to try out the new box lol Liquid_Ice posted at 7:55PM Fri, 22 January 2021 - #4410888
you can also unparent it and autofit it, see if that solves the problem. I did try that early on and got the same result
MarkCM ( ) posted Wed, 27 January 2021 at 6:09 PM
Had the same experience. Even with base G8F there's a little ripple there, although not nearly as obvious. I think it's the clothing item. It's an early G8F item, and doesn't auto-follow well. It's okay on G8F and V8 and some other characters, but doesn't even behave well with some other base figures.
It's a PC+ item, so it may not have cost you much, but if it's a recent purchase, I'd request a refund if you don't have characters it works well with.
DreamWeaver_Designs ( ) posted Wed, 27 January 2021 at 6:33 PM
I ended up dforcing it and that not only fixed the crunching but improved the over all look so and happy. Thanks for all the input everyone and if you want to see what I used it in have a look here: https://www.renderosity.com/rr/mod/gallery/the-druids-pool/2986725/
RHaseltine ( ) posted Thu, 28 January 2021 at 10:04 AM
It may be that there is a Rigidity Group assigned to the lower portion of the outfit - I know some early outfits did that, though I thought most were updated to remove the groups.
PendraiaFaeCreations ( ) posted Sat, 30 January 2021 at 7:00 PM
The menu item mentioned is called adjust rigging to shape but if that has already been done with the character it shouldn't be an issue. Richard's comment on a rigidity group is a possibility also. I personally manually convert a lot of stuff these days and create a custom morph for characters that have issues.
