Sat, Feb 8, 10:15 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: Poser 11 and Poser 12 running parallel on the same PC
joker2000 ( ) posted Sat, 06 March 2021 at 5:09 AM · edited Sat, 08 February 2025 at 10:13 AM
Hello can I can Poser 11 and Poser 12 at the same time on a PC? I would try to test Poser 12
parkdalegardener ( ) posted Sat, 06 March 2021 at 5:23 AM
Yes. I do it on two different machines.
joker2000 ( ) posted Sat, 06 March 2021 at 5:45 AM
parkdalegardener posted at 5:44AM Sat, 06 March 2021 - #4414382
I have only one fast machine. Can I install both versions on the same machine?
Afrodite-Ohki ( ) posted Sat, 06 March 2021 at 6:15 AM
joker2000 posted at 6:11AM Sat, 06 March 2021 - #4414383
Yes. Here's 12 and 11 running at the same time.
Their installations will work like this.
The Appdata/Roaming folders with the preferences of each one:
I can only confirm on Windows though, as I don't use Mac.
Feel free to call me Ohki!
parkdalegardener ( ) posted Sat, 06 March 2021 at 6:15 AM
Yes. I have both P11 and P12 running on the same machine. I have that configuration on two separate computers.
parkdalegardener ( ) posted Sat, 06 March 2021 at 6:16 AM
Aha crosspost. Haven't done that in years.
Afrodite-Ohki ( ) posted Sat, 06 March 2021 at 6:17 AM
parkdalegardener posted at 6:17AM Sat, 06 March 2021 - #4414387
I do that far too often for my tastes LMAO
RedPhantom ( ) posted Sat, 06 March 2021 at 6:18 AM
Site Admin
Yes, just don't install one over the other (use 2 different folders) but that's probably a given. I have 4 versions of poser on my machine. And I've had at least 3 of them running at the same time.
RedPhantom ( ) posted Sat, 06 March 2021 at 6:19 AM
Site Admin
Lots of cross-posts this morning. But the OP has his answer. 😄
hborre ( ) posted Sat, 06 March 2021 at 8:21 AM
Yes, both can coexist while open but don't try to render them at the same time.
randym77 ( ) posted Sat, 06 March 2021 at 7:17 PM
Not only can you run both versions, I highly recommend it. If you want to use your old Python scripts, you need to have Poser 11, since Poser 12 won't run them (yet).
There is a free 21 day trial, so you can see for yourself. One overwriting the other shouldn't be a problem, since Poser 11 installs in a folder called Smith Micro and Poser 12 installs in one called Poser Software.
Afrodite-Ohki ( ) posted Sun, 07 March 2021 at 1:33 PM · edited Sun, 07 March 2021 at 1:34 PM
hborre posted at 1:31PM Sun, 07 March 2021 - #4414392
I've rendered on CUDA GPU in P12 while rendering on CPU in p11 before. Was working alright :D
Didn't try both on GPU or both on CPU at once though - P11 can't render on my GPU, and rendering on CPU when I can use optix in P12 is too much of a waste of time.
Edit: alright yeah maybe don't try it if you're not running on a powerful computer. Mine's a bit of a freak.
an0malaus ( ) posted Mon, 08 March 2021 at 2:49 PM
Can confirm the same multi-version parallel Poser execution on macOS. I can't speak for simultaneous renders, though. I've never had a supported GPU, so each Poser instance would have to share the CPU. That's bound to be more efficient letting them run sequentially, though.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
RedPhantom ( ) posted Mon, 08 March 2021 at 7:25 PM
Site Admin
I don't have GPU rendering. I have tried duel CPU renders. If I set both renders to use half of the cores, it managed. If I forgot that, the computer shut down in protest.
