Mon, Feb 17, 6:22 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 17 1:20 pm)
Subject: Genesis 8.1 with morphs in Poser 12
infinity10 ( ) posted Sun, 07 March 2021 at 12:25 AM · edited Mon, 17 February 2025 at 6:18 PM
FBX exported from Daz Studio Pro and iported into Poser 12.
Default pose returned upon zeroing rotations after import, but posed version of exported FBX is not workable. Have to pose the imported figure inside Poser manually.
Superfly render with SS added.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 12:26 AM · edited Sun, 07 March 2021 at 12:26 AM
This was my posed Genesis 8.1 in Daz Studio Pro before exporting as FBX.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 12:44 AM
Here is the imported FBX with my own custom pose (manually done) in Poser 12.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 12:52 AM
So the default pose at frame one after zeroing rotations - OK.
My manually-posed version at frame 30 - OK.
Aaaaand - This is what every frame in the time line from 2 to 29 looks like:
So yes, I can do still portraits of Genesis 8.1 in Poser, but animation needs figuring out.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 2:38 AM
OK. I solved the static pose export.
From my scene with Genesis 8.1 in DS, I exported her pose as a BVH file. I imported her FBX into Poser, zeroed her figure and rotations, then imported the BVH.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 2:46 AM
For BVH import options: do not scale. Arms yadda = x-axis
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 3:32 AM · edited Sun, 07 March 2021 at 3:34 AM
OK. I set up a very short animation in DS, exported the BVH, then applied it to the imported FBX inside Poser 12. Genesis 8.1 does indeed animate inside Poser 12.
My video at Youtube
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 3:35 AM
Change the material of the cornea to a transparency = 0.95 in the Material Room. Add SSS.
Eternal Hobbyist
infinity10 ( ) posted Sun, 07 March 2021 at 5:27 AM · edited Sun, 07 March 2021 at 5:27 AM
I made a slightly longer animation in Daz Studio, exported it as BVH, and imported it for the FBX inside Poser 12.
My Youtube video here
Eternal Hobbyist
RedPhantom ( ) posted Sun, 07 March 2021 at 7:06 AM
Site Admin
Getting the model out seems pretty (okay sort of) straightforward, but what about all the textures? Is there a way to export those, or would I have to find the image maps and rebuild everyone?
infinity10 ( ) posted Sun, 07 March 2021 at 11:49 PM
RedPhantom posted at 11:48PM Sun, 07 March 2021 - #4414451
Daz Studio export as FBX will have a pop up screen to let you choose which option you prefer. I have all the textures embedded because it's just simpler for me.
Eternal Hobbyist
McGrandpa ( ) posted Fri, 12 March 2021 at 5:51 PM
Then there are people that do not install DS CMS/DIM (which means DS won't work). WHEN are we going to be able to simply read and use the DUF format in Poser?
My 66th Birthday PC Build (July 1, 2020) :  named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
infinity10 ( ) posted Fri, 12 March 2021 at 11:13 PM
McGrandpa posted at 11:12PM Fri, 12 March 2021 - #4414804
I don't understand what this has to do with exporting the model as an FBX fornat and then importing it as an FBX into Poser 12.
Eternal Hobbyist
McGrandpa ( ) posted Sat, 13 March 2021 at 2:16 AM · edited Sat, 13 March 2021 at 2:20 AM
It is the first key element in his process. As that user states, one must EXPORT the Figure first for POSER to IMPORT the Figure. Without the means to EXPORT that Figure, this is an exercise in futility. THAT is what it has to do with it. It is nice to know that the method works. But if one is so adept with DS then why bother with Poser? That seems the question posed by Users of DS and Poser in the old Usenet Newsgroup. Poser needs to be able to read and use the DUF format.
McG.
infinity10 ( ) posted Sat, 13 March 2021 at 3:02 AM
I stil don't understand how installing CS/DIM works in relation to exporting an FBX format of the assets. I'm sorry. It appears I have a basic lack of understanding of how this is necessary.
Eternal Hobbyist
Y-Phil ( ) posted Sat, 13 March 2021 at 1:28 PM
infinity10 posted at 1:22PM Sat, 13 March 2021 - #4414818
I have probably missed something imported because I just tested with a Vi8 out of the box: it comes in Poser 12 smoothly, in its default pose, but everything is exploded in the Hierarchy Window:
Result: the import doesn't work well. Example with one the default poses:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
infinity10 ( ) posted Sat, 13 March 2021 at 10:25 PM
Y-Phil posted at 10:24PM Sat, 13 March 2021 - #4414840
Yeah, the export options inside Daz Studio, I think... see my post of @4414441 - the screen capture truncates my Hierachy window in Poser, but you can see that there are no extra parts outside of the Genesis 8.1 figure
Eternal Hobbyist
Eternal Hobbyist
Y-Phil ( ) posted Sun, 14 March 2021 at 11:02 AM
infinity10 posted at 11:01AM Sun, 14 March 2021 - #4414851
Yeah, the export options inside Daz Studio, I think... see my post of 4414441 - the screen capture truncates my Hierachy window in Poser, but you can see that there are no extra parts outside of the Genesis 8.1 figure
Any hint?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
infinity10 ( ) posted Sun, 14 March 2021 at 11:26 AM
@Y-Phil - try using the 2019 FBX instead of the 2014 FBX export.
Eternal Hobbyist
Y-Phil ( ) posted Sun, 14 March 2021 at 11:31 AM
infinity10 posted at 11:29AM Sun, 14 March 2021 - #4414872
Aha... I understand...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
infinity10 ( ) posted Mon, 15 March 2021 at 12:35 AM
@y-phil - My apologies.
Here is my screen capture of the Genesis8.1 export to FBX to produce that image I posted early in this thread. ( As also mentioned, the motion does not translate over, and I have to separately export the BVH and then apply it in Poser to get the figure posed.)
Eternal Hobbyist
Y-Phil ( ) posted Mon, 15 March 2021 at 4:40 AM · edited Mon, 15 March 2021 at 4:41 AM
infinity10 posted at 4:36AM Mon, 15 March 2021 - #4414905
Definitely better! Huge thankies... ??? And... without "Animations" checked because I retrieve a kind of small stack of things... lol
Test done with a Gen8 character, created by a friend. The next step: the materials, but I'll do that later ❤
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
infinity10 ( ) posted Mon, 15 March 2021 at 8:34 AM
@Y-Phil - COOL !!
Eternal Hobbyist
Y-Phil ( ) posted Mon, 15 March 2021 at 5:29 PM
Here is the final result, using Cycles and double-layer system:
Not really useable in a close-up, as it doesn't seem to be changed to poser-unimesh, so: no subd. Anyway, I'm happy with this...
Thank you so much @infinity10 ??
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Boni ( ) posted Thu, 29 July 2021 at 4:48 PM
Ok ... I'm confused. (that's no surprise) ... why do we need to import a BVH? If imported properly into Poser do the figures actually have access to all their morphs (both Posing and Shape). Because I see under the "yes" the whole list of poses and "not used" noted. Do I have to animate the figure to have the poses available? I try turning a head and the head elements don't follow and the head is distorted.
Boni
Boni ( ) posted Thu, 29 July 2021 at 6:46 PM
Ok ... I think I've figured it out. The rigging is just treated way different from the native Poser figures. I like this. Thank you!!
Boni
primorge ( ) posted Fri, 30 July 2021 at 10:28 PM
Can I be a stick in the mud and say I'm not seeing anything being done above in those images that can't be achieved with any number of Poser native figures. With a gigantic less amount of headaches.
primorge ( ) posted Fri, 30 July 2021 at 10:30 PM
Or in the chasing of the unicorn did everyone lose sight of that simple fact?
Boni ( ) posted Sat, 31 July 2021 at 7:19 AM
A very good point primorge. But the genesis figures do have the advantage of having far more detailed characters and rigging and natural poses than most of the native Poser figures. The variety is also nice to have. Heck I still have Dina and Andrea Delgato!!
Boni
ssgbryan ( ) posted Thu, 05 August 2021 at 10:43 AM · edited Thu, 05 August 2021 at 10:44 AM
primorge posted at 10:32AM Thu, 05 August 2021 - #4424282
One of the things I have noticed is that with a number of vendors, all of their characters look like they are very, very closely related. In addition, I need more than early '20's Caucasians.
So I need things like Kala 8, Sanjay 8, Latonya 8, Mrs. Chow, Sydney 8, Alexandra 8, Khemsit 8, Twoset 8 Josie 8, Edie 8, Monique 8, Ashan 8, Darius 8, Diego 8, Edwards 8, Floy i, Silas 8, Vladimir 8, etc.
In addition, most non-V4/M4 characters lack a basic wardrobe; with the clothing conversion software that is available (and has been available in some form for over a decade), my characters have quite the extensive wardrobe.
Yes, it is more work, yes, I would prefer to buy native clothing. But vendors for post V4/M4 are not going to make anything that doesn't "excite" them. So, if I need "non-exciting" clothes, I use the features available in Poser.
McGrandpa ( ) posted Mon, 27 September 2021 at 11:18 PM
infinity10 posted at 3:02 AM Sat, 13 March 2021 - #4414818
One more and the last time:   Begin-[ You can NOT get anything at all done with DS 4.xx *UNLESS* the DIM and CMS combo are installed and *RUNNING* with the CMS logged into DAZ3D.    All that sentence is prerequisite to USING DAZ Studio 4.xx which obviously has to work properly to load and export models, regardless of the format chosen. ]-End
SO, what other way is there to get the duf format Genesis 3 through 8.1 Figures into Poser?  There is a way.   IT is written and working.   But a "Power That Be" (the one in charge of all Poser development) stomped their foot down and said "There is no way in Hell Poser will ever use Genesis 8!"
It is everything to the discussion from MY viewpoint.
McG.
randym77 ( ) posted Tue, 28 September 2021 at 5:52 AM
McGrandpa posted at 11:18 PM Mon, 27 September 2021 - #4428216
I think you are mistaken.  Bondware asked about getting DSON updated to work in Poser 12, and DAZ said no. Heck, DAZ has removed DSON from their site entirely. That was not Bondware's choice.
hborre ( ) posted Tue, 28 September 2021 at 8:18 AM
Before making blunt statements, get the facts straight and factual.  Speculation and opinion are not rooted in the truth.  Do some background research first, it will save an embarrassment later.
