Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Erm, no, I wasn't using Pro 2012, I was using Poser 11. I have Pro 2012 but hardly use it. :)
Setup room can be tricky in Poser I remember that SM fixed some issues on the last Poser 11 update due crashes when changing the Hierarchy order on a model. Crashes normally occur if you try changing an upper part of a Hierarchy chain reparenting them to another body part it is where a crash might happen. In my case I even had crashes that caused the Licence to blow off using the Setup room. SM gave me support at the time to get a stable Infinite Licence ! really bad crashes can happen if you Move or delete a single bone in the hierarchy chain that is not last having attached bones on it .
In your case as I can't see the Hierarchy you actually have and how you want to change it you might consider rebuilding it. On Models I create I use bridges with Blender, Hierarchy Bone and Modeling surface issues are fixed in Blender sending it back to Poser from there i just copy Paste the rigging that already was done back to the model, this way I do not have to re rig the whole thing and can move on from the latest point .
I never use the Setup Room. I import each piece, parent them in the Hierarchy Editor, hit Create New Figure and there you go. Then, I set up the joints, limits and all that stuff.
It's usually a simple, easy way to rig hard surface models, such as mine.
Anyhow, I deleted the file and created it again. This one works properly.
Anyone else have this problem? Using Pro 2012.
Rigging one of my model Daleks and I noticed I'd parented the arm parts incorrectly, so I'm trying to parent them in the right order but every time I try, Poser crashes. When I try to parent to Universe, nothing happens at all, so I tried to parent to the figure's main section, which is when the crash occurs.
I guess it's going to be simpler to create the figure again - it's no real hardship - but it would be good to know why this happens and what to do about it.
