Wed, Feb 26, 12:56 PM CST
Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 23 8:32 pm)
banner
Subject: Animation renders crash every time.
Taborton ( ) posted Wed, 31 March 2021 at 12:04 PM · edited Sat, 01 February 2025 at 2:26 AM
I'm working on a 2013 MacPro, 3.5 6 core, 64 GB ram, AMD FirePro D500 3 GB. I have success when rendering to preview but when I attempt to render the same 30 frames to Firefly it crashes. It may have worked once out of 15 attempts. I tried changing movie output settings to image files and it renders 2 - 3 files and crashes. The project file is 139MB. I'm working with dreamland 81 blocks. Render settings are full quality auto, use displacement maps, depth of field checked. Progressive mode. Any help would be appreciated.
Richard60 ( ) posted Wed, 31 March 2021 at 12:35 PM
If you can render to a single image with FireFly then most likely it is the progressive settings. Since you are doing an animation you are going to have to let each frame render out fully. Other then that not sure as I have used the 81 City Blocks model in several movies suing Poser 9/10 and 11.
Taborton ( ) posted Thu, 01 April 2021 at 9:24 AM
Turning off progressive did the trick, thank you Richard60!
