Sat, Jan 18, 12:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 12:01 am)
Subject: Grey Ship and Grey Havens (port) project
seachnasaigh ( ) posted Fri, 02 April 2021 at 11:33 PM · edited Sat, 18 January 2025 at 12:41 AM
For Lord of the Rings fans... the Grey Havens port, and a grey ship in which to sail into the west...
Coming soon to a freestuff section near you. Still need to save out PP2 files, extract OBJs, etc.
hborre ( ) posted Sat, 03 April 2021 at 7:42 AM
Very impressive. A beautiful set.
randym77 ( ) posted Sat, 03 April 2021 at 8:23 AM
Wow. Stunning!
VedaDalsette ( ) posted Sat, 03 April 2021 at 9:07 AM
I'm not a Lord of the Rings fan, but I'm a fan of these images!
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Miss B ( ) posted Sat, 03 April 2021 at 1:02 PM
Excellent work Seach, as usual. I look forward to playing with it, when you have it finalized.
_______________
Butterfly Dezignz
Sunfire ( ) posted Sat, 03 April 2021 at 3:58 PM
Very nice!
Sunfire's Creations
Digitell ( ) posted Sun, 04 April 2021 at 8:53 AM
Forum Coordinator
Gorgeous piece of work! 👍
The Artistic Cat
seachnasaigh ( ) posted Tue, 06 April 2021 at 10:54 PM · edited Tue, 06 April 2021 at 10:56 PM
Thank you, fellow Poser folk! :D
This set has been uploaded to freestuff. If someone spots a critical error, please notify me. You should see this in your props library: Grey Havens prop library.PNG
suggested render settings for P12:
In P11, use maybe 30 pixel samples. P12 can use much higher if adaptive sampling with threshold is set (I used 0.003) because Superfly will consider a pixel which hasn't changed in the last several raytraces to be finished, and skip it thereafter, concentrating on those areas which still need refinement.
These test shots were done with the final prop set (OBJs extracted, etc), exactly what is packed in the freestuff zip:
RoseHawk ( ) posted Wed, 07 April 2021 at 4:46 AM
Very nice. off to d/l!
Improvement means change. Change need not mean improvement.
I use Poser 12.0.757, 11.3 and or 2014, on Win10 64bit.
RoseHawk ( ) posted Thu, 08 April 2021 at 11:26 AM
Thanks for this great set. Now I've had a chance to load it I have a couple of observations.
The preset "!Grey Ship at sea.pp2" calls two of Lisa’s Botanicals products. For somebody who do not have these, you get a lot of "file not found" errors. A preset without these (like the planter.pp2's) would fix this.
!Grey Ship at sea.pp2 the ship mooring ropes are visible, (easily fixed by turning their visibility off.)
Question. Are Lisa’s Botanicals products available? Specially the tulips and cherry trees.
Thanks again :)
RoseHawk ( ) posted Thu, 08 April 2021 at 1:15 PM
My apologies. The visible mooring ropes mentioned above was my error, some how they got left in when I cleared the stage before loading !Grey Ship at sea. Sorry please ignore my remark.
seachnasaigh ( ) posted Thu, 08 April 2021 at 4:58 PM · edited Thu, 08 April 2021 at 5:01 PM
RoseHawk posted at 4:44PM Thu, 08 April 2021 - #4416499
Thanks again :)
Good point; I have updated the zip so that now it has both !Grey Ship in harbor and !Grey Ship in harbor w LB plants preloads.
This set is much bigger than the default construct, so set each camera's yon higher:
I don't know if Lisa's plants will be transferred to Renderosity's store; she died recently, and featuring them in this set was a sort of remembrance to her.crypb.gif
RoseHawk ( ) posted Thu, 08 April 2021 at 5:55 PM
I've answered my own question. Lisa’s Botanicals are available in the store.
Sorry I can not get a working link, just search Lisa’s Botanicals
RobZhena ( ) posted Thu, 08 April 2021 at 6:50 PM
LoR renders aren't my thing, but I thank you for your incredible efforts and generosity to the Poserverse over the years. You rock.
Miss B ( ) posted Thu, 08 April 2021 at 8:35 PM
RoseHawk posted at 8:35PM Thu, 08 April 2021 - #4416547
Here you go . . . https://www.renderosity.com/rr/mod/bcs/vendor/Lisas_Botanicals
_______________
Butterfly Dezignz
seachnasaigh ( ) posted Mon, 12 April 2021 at 4:50 PM
For those who have downloaded the Grey Havens, watch the freestuff for an SR3 for the Grey Havens. It corrects the grid artefact on the harbor water, fixes a UV smear at the corners of the pier steps, etc. I also have a little skiff (small sailboat) and a ferryboat with a horse bay nearing completion.
Skiff shown in foreground:
Cycles water test 4C auto-tiled sea w movie.jpg Note that the grid artefact which showed on the water surface is fixed, as is the UV smear at the corner of the pier steps.
seachnasaigh ( ) posted Tue, 13 April 2021 at 4:37 AM
The redux of the Withywindle ferry includes lap strakes for the hull and UV-unwrapping of the railing scrollwork. I'm not satisfied with the bow wave, or even the harbor water at this angle of camera and sun. Harry the HiveWire horse stands in the central well.
seachnasaigh ( ) posted Thu, 15 April 2021 at 3:14 PM
Corrected the loss of UVs on the ferry's hull strakes and rail filigree, now working on the water material...
After re-extracting the OBJs, etc., I'll upload an SR3 for Grey Havens. The ferry boat and the skiff will be separate uploads.
RoseHawk ( ) posted Thu, 15 April 2021 at 5:43 PM
Right, while I'm waiting I'll keep fiddling with this:
GrayHavenV3.pngGrayHavenV3-1.png.
still a lot to do.
seachnasaigh ( ) posted Thu, 15 April 2021 at 7:53 PM
Yay! I've only rarely seen renders made using anything I've made; it's neat to see what someone does with it. pbhappyjump.gif
The depth of field has plenty of distance in which to work.
