Wed, Dec 4, 8:40 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: The Geograft Fake Out Trick
MistyLaraCarrara ( ) posted Wed, 07 April 2021 at 12:13 AM · edited Wed, 04 December 2024 at 8:14 PM
loading the Minotaur Tail to G2M or the pro anatomical parts,
the geograft punches a hole in the mesh and renders uv artifact symbols.
Fake out the geograft,
conform an invisible underwear or cod piece to genesis#, then conform the geograft tail or whatnots to the underwear. or any other minimal geometry.
morph flow down, depending on the body shape and scale, you may need to transfer the morph to the underwear, if the tail has a particular support morph, you could try manually dialing the morph.
have you
If using this trick on the male anatomical pro geografts, applying transparency to the 'hip' skin
headwax. ( ) posted Wed, 07 April 2021 at 2:51 AM
Thanks !
diomede ( ) posted Sat, 24 April 2021 at 11:11 AM
Thanks for tips. Haven't used geografts in a while. Seems to me that the last time I did, I did a double geograft. I applied the first geograft to the figure and it appeared with messed up UVs. I then conformed a second geograft on the first geograft, not to the base figure. The second geograft UVs were NOT messed up. turned off visibility for the first geograft. Wasnt the pro bits, but I suspect the principle is the same.
ProPose001 ( ) posted Fri, 21 May 2021 at 7:55 PM
Speaking of the Pro Bits, I figured a way to attach the G8F gens to Veronica without messing up the uvs. I'd show a render but not sure if it's allowed
MistyLaraCarrara ( ) posted Fri, 21 May 2021 at 9:46 PM
ProPose001 posted at 9:44PM Fri, 21 May 2021 - #4419635
theres a checkbox for a nudity warning. bottom of the message box
ProPose001 ( ) posted Sat, 22 May 2021 at 3:57 AM
