Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Visit the Carrara Gallery here.
Thanks for tips. Haven't used geografts in a while. Seems to me that the last time I did, I did a double geograft. I applied the first geograft to the figure and it appeared with messed up UVs. I then conformed a second geograft on the first geograft, not to the base figure. The second geograft UVs were NOT messed up. turned off visibility for the first geograft. Wasnt the pro bits, but I suspect the principle is the same.
ProPose001 posted at 9:44PM Fri, 21 May 2021 - #4419635
Speaking of the Pro Bits, I figured a way to attach the G8F gens to Veronica without messing up the uvs. I'd show a render but not sure if it's allowed
theres a checkbox for a nudity warning. bottom of the message box
loading the Minotaur Tail to G2M or the pro anatomical parts,
the geograft punches a hole in the mesh and renders uv artifact symbols.
Fake out the geograft,
conform an invisible underwear or cod piece to genesis#, then conform the geograft tail or whatnots to the underwear. or any other minimal geometry.
morph flow down, depending on the body shape and scale, you may need to transfer the morph to the underwear, if the tail has a particular support morph, you could try manually dialing the morph.
have you
If using this trick on the male anatomical pro geografts, applying transparency to the 'hip' skin
