Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Yes, that's what I used to do. However, in P11, I discovered if I unchecked Visible in Camera and Visible in Raytracing but left Visible checked, it would not only remain hidden during the render, but during posing, I could mouse-hover and select it. That's something I couldn't do if Visible was unchecked.
But I realize now, I never used Superfly in P11, except toward the end. I should see if this same disparity occurs in P11.
W11,Intel i9-14900KF @ 3.20GHz, 64.0 GB RAM, 64-bit, GeForce GTX 4070 Ti SUPER, 16GB.ย
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
I guess this feature is something that only works in Firefly, not Superfly. I tested it in P11. Results are the same as P12. Oh, well, I guess that's that. I guess it's all part of my learning curve transitioning from Firefly to Superfly.
P11 Superfly render
P11 Firefly render
Old lady hobbyist.
Just a small question: why not use the morphing tool in "Tighten Fit" mode on the cloth, with the goal set to your character?
Example: Morphing Tool
Start with "Pokethrough Margin" set to 4 or 6, or more if necessary. It works on dynamic clothing. too.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
I LOVE the morphing tool! But what I was showing in this example was clothing I purposely scaled down to create pokethrough (the Pixpax bolero actually fits La Femme perfectly!). I just did this to provide an example, because I noticed in P12 the visibility boxes weren't working in Superfly like they had in Firefly. I hadn't realized this disparity occurred in P11 already, until I just tested it.
Sorry if this is unclear, but using Firefly I'd gotten spoiled mouse-hovering to select body parts I'd unchecked (visible in camera and visible in raytracing). Now, with Superfly, I'll just have to using the dropdown menu to select. It's a very minor issue but a UI difference between Firefly and Superfly.
Thanks so much, 3Dpixi and Y-Phil, for your responses.
Old lady hobbyist.
Aha... oops! And sorry if I misread your message... ??
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
You can uncheck visible, or visible in camera and visible in raytracing to hide something for superfly. I use the latter frequently for body handles. But there seems to be a bug with Lafemme as the visible in camera and visible in raytracing method doesn't work with her or L'homme. It does work with older figures.
I did a little more testing and it seems that it doesn't work with figures with poser unimesh skinning in superfly. It works with firefly. If you convert Lafemme to poser traditional, it works, but then you lose the subdivition.
Poser 12.0.471. Results are the same in Poser 11.
Red Phantom is correct! It's the skinning method that affects these renders, so I guess this isn't a bug.
I've got 3 Poser gals here and left skinning at their defaults (LF unimesh, Pauline unimesh, Jessi traditional). I conformed their shirts on them, left their skinning at defaults (same as their character figures), and scaled the clothes down overall to 95%. I also disconnected any displacements.
Then I went in to each of the character figures and unchecked Visible in Camera and Visible in Raytracing for each of their right collars and right shoulders. I unchecked Cast Shadows for these, too. I kept the Visible box checked for these.
Then I went into the clothes and unchecked Cast Shadows for their right collars and right shoulders.
Here's the preview (screen capture).
Firefly render.
Superfly render.
Superfly with all clothes traditional skinning.
Superfly with all clothes and all characters traditional skinning.
Old lady hobbyist.
This happened on a couple of figures. In the example below, I purposely scaled down La Femme's bolero so there'd be collar pokethrough. I had set her right collar to not be visible in camera or raytracing. However, when I rendered, her right collar was visible.
I tried another Superfly render (low non-branched GPU). Same result. Then I tried Firefly. The collar was hidden in the render.
Is this a known issue?
Old lady hobbyist.
