Wed, Feb 26, 3:36 PM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 25 7:07 am)
Subject: Render Settings help
sasacatina ( ) posted Thu, 06 May 2021 at 6:25 AM · edited Fri, 21 February 2025 at 11:51 PM
Hello! I am new to this program, coming from poser 11. I am having a bit of trouble figuring out how to make a good render of high quality without it being a huge file. I usually render my pictures in poser 11 as 8in x 11in at 150 resolution. What would the equivalent settings be in DAZstudio? Pictures or step by step would be grand!
oldingr ( ) posted Thu, 06 May 2021 at 7:20 AM
In DS you use the Render settings under GENERAL you can select DEMENSION/CUSTOM. DS renders at 96 dpi and I don't believe there is a way to change that but you could just render at 150x8=1200 and 180x11=1650, So your render size would be 1200 x 1650 or you could just use 96dpi to get a physical print size of 8x11 which would be 768x1056 in the render size settings. But I usually render things at a higher resolution and resize in photoshop which seems to work better.
sasacatina ( ) posted Thu, 06 May 2021 at 7:26 AM
Ah, alrighty, thank you!
jestmart ( ) posted Thu, 06 May 2021 at 9:44 AM
Studio does not set a DPI on rendered images. Any DPI you see when viewing an image is a default value the viewing program is adding.
RHaseltine ( ) posted Thu, 06 May 2021 at 9:44 AM
Nothing renders at a PPI value, it's just a number added to the front of the final output to say how big a pixel should be. DS leaves the value blank, so your viewer or editor will assign its default - usually either 72 or 96.
