Very nicely done, Miz O! It is like taking a peek inside your home. The figurines are wonderful and look very fragile. Your fabric material is quite fine, quite fine! Glad you gave it a try! :D When you open the Material Editor, you'll see a tab for Bump. Click the tab to open the Bump production area. You can create a bump using the procedural functions and filters, or you can use an image map.
You can use an image map? Can't seem to find where to load one in. Think there's lots of things hidden in here. I suppose reading the manual cover to cover would help... I need better glasses, that print is small. Oh... I can't find the vegitation builder. Thought I had it, got the material list, but I only had one tree in so it gave me just the list for that. Oh well, I'll find these things eventually. Thanks Varian. /// Oh and sorry, the flowers are Catherine's flower props out of poser.)
IT is beautiful!!!! I adore the glass statues and the mirror :) Re the bump creations, as Varian said in the material editor, choose the bump tab, then select to edit the filter (right click), select mapped values and then use your image map as your bump :) You can edit all of the functions in the same manner, including the transparency tab.....by selecting variable transparencies, edit filter and once again choose mapped values and use the image again - if u have it (the image) inverted, you can create beautiful doileys with it.
Wow I think it is wonderful, just really eye catching, you did a great job. As far as texturing, I know how you feel, I am still practicing at it. It is not something you can just whip up I know that, it does take time and a little knowledge, at least for me. But you did a great job. I wouldn't change anything, it is great. Sharen
Beautiful picture, Ms! Those glass statues turned out very well, as well as the flowers, and everything. There is alot hidden in Vue's material editor, actually, and in fact, most of it is covered only very vaguely in the manual, so the best thing to do is to ask specific questions, and do alot of experimenting....
Looks very beautiful and the glass objects are very convincing ! Nothing bad to say :-) As Varian said you can use bitmaps for bumps. You can use color images (sometimes the same you used for the material) or grey scale images. In the BUMP tab of your material editor, right-click in the bump production window and choose "EDIT FUNCTION" from the list. In the bnew window, click at MAPPED VALUES and choose the file you want to use. Click OK and again OK. And if you want to save your bitmap as afunction file, just save it. Again right-click in the bump edition window and choose "SAVE FUNCTION". :-)Guitta
